The V7 27" LED monior is designed with style, high screen performance and environmental features for home, work and everything in between, the L27000WHS, utilizes a low power LED backlight and saves on space while giving you a sharp, dazzling view in Full HD at high resolution. With stunning screen appeal, you will have a sharp, detailed, Full HD view while surfing the internet, working on projects, editing videos or streaming shows online. High screen performance includes 30,000,000:1 dynamic contrast ratio, 200 nits brightness, 5 ms response time, plus the low power LED backlight helps reduce the environmental footprint. This sleek LED widescreen monitor is a great value and looks sharp on every desktop. With both a VGA and HDMI input you are sure to enjoy the highest resolution possible.
- V7 L27000WHS - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A+
- Energy Consumption per Year
- 33 kWh
- Power Consumption (On mode)
- 22 W
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 200 cd/m²
- Contrast Ratio
- 30000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA
- Tilt
- Voltage
- AC 120/230 V
- 57.5 cm x 18 cm x 49.3 cm
- 5.97 kg
- Localisation
- United Kingdom
- FCC, RoHS, WEEE
- 3-year warranty
- Display Type
- Energy Class
- Class A+
- 33 kWh
- Diagonal Size
- 27"
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- 57.5 cm x 18 cm x 49.3 cm - with stand
- 5.97 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- HDMI , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 75 x 75 mm
- Cables Included
- 1 x VGA cable
- FCC, RoHS, WEEE
- Localisation
- United Kingdom
- Input Voltage
- AC 120/230 V
- 22 W
- On / Off Switch
- Included Software
- Drivers & Utilities
- OS Required
- Apple MacOS X, Microsoft Windows Vista, Microsoft Windows XP / 7 / 8 or later
- Dimensions & Weight Details
- With stand - width: 57.5 cm - depth: 18 cm - height: 49.3 cm - weight: 5.97 kg , Without stand - width: 63.2 cm - depth: 4.7 cm - height: 38.6 cm
- Limited warranty - 3 years - pick-up and return
