The V7 24" Class LED monitor is designed with style, high screen performance and features for home, work and everything in between. The V7 LED widescreen monitor utilizes a low-power LED backlight contributing to a reduced environmental footprint while displaying sharp, dazzling images in Full HD 1920x1080p resolution.
With the HDMI input, you can connect to your PC, game console, or DVD player, providing the perfect multipurpose display.
The high performance specifications includes 30000000:1 contrast ratio, 200 nits brightness, and 5ms response time. This large widescreen screen LED monitor is a great value and looks sharp on every desktop. With both VGA and HDMI inputs, you are sure to enjoy the highest resolution possible.
The V7 LED monitor comes fully equipped with two built-in on-board speakers for the complete audio-video experience.
- V7 L23600WHS-9K - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A+
- Energy Consumption per Year
- 27 kWh
- Power Consumption (On mode)
- 18 W
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 200 cd/m²
- Contrast Ratio
- 30000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA
- Speakers
- Integrated
- Tilt
- Voltage
- AC 100/240 V
- 55.9 cm x 18 cm x 42.2 cm
- 4.2 kg
- Localisation
- United Kingdom
- FCC, RoHS, WEEE
- 3-year warranty
- Display Type
- Energy Class
- Class A+
- 27 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.6"
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Slim bezel design
- 55.9 cm x 18 cm x 42.2 cm - with stand
- 4.2 kg
Audio
- Speakers - integrated
- Output Power / Channel
- 2 Watt
- VGA (HD-15) , HDMI , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 75 x 75 mm
- Included Accessories
- Stand
- Cables Included
- 1 x VGA cable , 1 x power cable
- FCC, RoHS, WEEE
- Localisation
- United Kingdom
- Input Voltage
- AC 100/240 V
- 18 W
- On / Off Switch
- OS Required
- Apple MacOS X, Microsoft Windows Vista, Microsoft Windows XP / 7 / 8 or later
- Dimensions & Weight Details
- Without stand - width: 55.9 cm - depth: 4.7 cm - height: 31.5 cm
- Limited warranty - 3 years
