V7 2-POINT Telescopic Deskmount
Quicklinx: BFL2WS00 Mfr#: DS2DA-2E
The full motion mounting arm connects directly to your desktop or table and hold flat panel displays from 10" to 24". This high quality mount allows you to swivel and rotate your display into nearly any position. The cable management channel keeps video and power cables organized. Installation is easy with the clamp mounting hardware included.
V7 mounting kit - for LCD display - black
Mounting kit
Mounting Components
Desk clamp mount, pole, full motion arm
10 cm x 33.6 cm x 40.3 cm
Adjustments
Tilt
2.4 kg
Recommended Use
LCD display
Recommended Display Size
10"-24"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
6 kg
5-year warranty
10 cm
33.6 cm
40.3 cm
2.4 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
Cable Management
Integrated cable management
10"-24"
Adjustments
Tilt
Max Load Weight
6 kg
Adjustable height, adjustable depth, rotating, swivel adjustment
Limited warranty - 5 years
