Your basket is empty
V7 2 Arm Monitor Deskmount
Quicklinx: BFL4WS00 Mfr#: DS2GSA-2E
The V7 full motion gas spring mount connects directly to your desktop or table and hold flat panel displays from 10" to 24". This high quality mount allows you to swivel and rotate your display into nearly any position while the self-stabilizing gas spring keeps your image level. The cable management channel keeps video and power cables organized and out of sight. Installation is easy with the clamp or gourmet mounting hardware included.
V7 - mounting kit
Mounting kit
Mounting Components
Desk clamp mount, grommet mount, full motion arm
10 cm x 40 cm x 51 cm
Tilt
3.22 kg
Recommended Use
LCD display
Recommended Display Size
10"-24"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
5 kg
5 years warranty
10 cm
40 cm
51 cm
3.22 kg
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
Cable Management
Integrated cable management
10"-24"
Tilt
Max Load Weight
5 kg
Adjustable height, adjustable depth, rotating, swivel adjustment, gas-spring technology
Limited warranty - 5 years
