Your basket is empty
V7 1GB DDR DIMM 400MHZ CL3
Quicklinx: BDP1WS00 Mfr#: V71T1GNSKCI
Upgrading the memory in your desktop or notebook is one the most cost effective ways to boost performance. Memory upgrades are quick and easy to install. Adding extra memory ensures that the operating system and applications run faster and smoother and is essential for applications such as gaming, HD video and image editing, graphic design, multi-tasking and manipulating large amounts of data. Upgrading is also an easy way of extending the life of your system
V7 - DDR - 1 GB - DIMM 184-PIN
RAM memory
1 GB
Memory Type
DDR SDRAM - DIMM 184-PIN
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
400 MHz (PC3200)
Latency Timings
CL3
Unbuffered
10 years warranty
1 GB
Upgrade Type
Generic
DRAM
DDR SDRAM
DIMM 184-PIN
Speed
400 MHz (PC3200)
Latency Timings
CL3
Non-ECC
Unbuffered
Compatible Slots
1 x memory - DIMM 184-PIN
10 years warranty
