This V7 19" LED monitor provides outstanding image quality with vivid colors and lifelike images. The LED backlight technology saves you up a lot of energy and yields blacker blacks, pure whites and more clearly defined grays for a vivid picture making it the perfect choice for home or office. The monitor features 1366x768 HD resolution, 16:9 aspect ratio, 200 nits brightness, reduced blur with 5 ms response time and customized picture settings to fit your needs. The L18500WS-9K reduces clutter and provides more desk space while sitting in a glossy bezel. The widescreen monitor is easily wall mountable and provides a tremendous price to performance value.
- V7 L18500WS-9K - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Energy Class
- Class A+
- Aspect Ratio
- 16:9
- Native Resolution
- 1366 x 768
- Brightness
- 200 cd/m²
- Contrast Ratio
- 1000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA
- Tilt
- Voltage
- AC 120/230 V
- 44.2 cm x 18 cm x 35.7 cm
- 2.65 kg
- Localisation
- United Kingdom
- FCC, RoHS, WEEE
- 3-year warranty
- Display Type
- Energy Class
- Class A+
- Diagonal Size
- 19"
- Viewable Size
- 18.5"
- Aspect Ratio
- 16:9
- Native Resolution
- 1366 x 768
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 60 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- 44.2 cm x 18 cm x 35.7 cm - with stand
- 2.65 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 75 x 75 mm
- Included Accessories
- Stand
- Cables Included
- 1 x VGA cable
- FCC, RoHS, WEEE
- Localisation
- United Kingdom
- Input Voltage
- AC 120/230 V
- Dimensions & Weight Details
- Without stand - width: 44.2 cm - depth: 4.7 cm - height: 27 cm , With stand - width: 44.2 cm - depth: 18 cm - height: 35.7 cm
- Limited warranty - 3 years
