Your basket is empty
V7 18.5" 1366x768 5MS VGA LED Monitor with Speakers
Quicklinx: BN4VWS00 Mfr#: L18500WS-9K
This V7 19" LED monitor provides outstanding image quality with vivid colors and lifelike images. The LED backlight technology saves you up a lot of energy and yields blacker blacks, pure whites and more clearly defined grays for a vivid picture making it the perfect choice for home or office. The monitor features 1366x768 HD resolution, 16:9 aspect ratio, 200 nits brightness, reduced blur with 5 ms response time and customized picture settings to fit your needs. The L18500WS-9K reduces clutter and provides more desk space while sitting in a glossy bezel. The widescreen monitor is easily wall mountable and provides a tremendous price to performance value.
V7 L18500WS-9K - LED monitor - 19"
LED-backlit LCD monitor - 19"
Energy Class
Class A+
Aspect Ratio
16:9
Native Resolution
1366 x 768
Brightness
200 cd/m²
Contrast Ratio
1000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
44.2 cm x 18 cm x 35.7 cm
2.65 kg
United Kingdom
FCC, RoHS, WEEE
3 years warranty
Display Type
Energy Class
Class A+
Diagonal Size
19"
Viewable Size
18.5"
Aspect Ratio
16:9
Native Resolution
1366 x 768
Brightness
200 cd/m²
Contrast Ratio
1000000:1 (dynamic)
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 60 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
44.2 cm x 18 cm x 35.7 cm - with stand
2.65 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
75 x 75 mm
Stand
1 x VGA cable
FCC, RoHS, WEEE
United Kingdom
AC 120/230 V
Dimensions & Weight Details
Without stand - width: 44.2 cm - depth: 4.7 cm - height: 27 cm , With stand - width: 44.2 cm - depth: 18 cm - height: 35.7 cm
Limited warranty - 3 years
