Product
Brand
V7 16GB Dual Flash Drive - Black
Quicklinx: BDQGWS00 Mfr#: VUOTG16G-BLK-3E
Upgrade your mobile storage with the V7 Dual Connector OTG (on-the-go) flash drive. Equipped with a full sized USB 2.0 and Micro USB connector for compatibility with laptops and Android 4.0 & up based tablets or smartphones.
V7 VUOTG16G-BLK-3E - USB flash drive - 16 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
16 GB
Enclosure Colour
Microsoft Windows 98, Microsoft Windows 2000, Microsoft Windows XP, Apple MacOS 9.x or later, Microsoft Windows 7, Microsoft Windows Vista, Linux Kernel 2.4 or later, Windows 8, Android 4.0 or later
5 years warranty
USB flash drive
Storage Capacity
16 GB
Enclosure Colour
Compatibility
Non-specific
Read Rate
Up to 12 MB/s
Write Rate
Up to 4 MB/s
Interface Type
USB 2.0
Dustproof, retractable connector, USB On-The-Go compatible, aluminum body, dirtproof, USB and micro-USB Dual connector
Plug and Play, FCC, RoHS, WEEE
Limited warranty - 5 years
9 mm
19 mm
59 mm
9 g
