Urban Armor Gear Plasma Series for MacBook Pro 15" with Touch Bar (4th Gen)
Quicklinx: FKFLWS00 Mfr#: MBP15-4G-L-IC
Engineered to provide protection for an active mobile lifestyle, UAG brings you the first rugged MacBook Pro 13-inch that meets MIL-SPEC 810G-516.6 drop test standards. The patented composite design fuses a hard outer shell with soft impact resistant bumpers engineered to protect your MacBook Pro 13-inchfrom drop and shock. The unique 1-piece design and soft rubberized bumpers and bottom skid pads provide 360-degree protection from scratches and abrasions. With oversized ports and a low profile design that slips in and out of your bag, access is always fast and easy. Available in a clear translucent color, UAG's rugged and lightweight MacBook Pro 13-inchcasesare sure to make you stand out from the crowd whether at work or the next expedition. Compatible with the MacBook Pro 15-inch with Touch Bar (4th Gen, 2016-20018) Model Number: A1707 & A1990.
UAG Rugged Case for MacBook Pro 15-inch w/ Touch Bar (4th Gen, 2016-2018) - notebook shell case
Notebook shell case
Ice
Product Material
Rubber
37.08 cm x 25.27 cm x 2.39 cm
400 g
Notebook Compatibility
15"
Shock-resistant, abrasion resistant, drop-resistant, impact-resistant, scratch-resistant
Apple MacBook Pro 15.4" (Late 2016)
Notebook shell case
Product Material
Rubber
37.08 cm
25.27 cm
2.39 cm
400 g
15"
Ice
