The Plasma Series Healthcare Case for the Microsoft Surface is designed for healthcare providers who depend on their tablet in hospitals, clinics, and other healthcare environments. Meets Mil-Spec 810G, this case has passed rigorous testing for 1.2-meter (4 feet) drops to help protect your device against accidental drops. With functional components like a 360-degree rotational hand strap, a built-in kickstand to transform the tablet into a laptop with ease. Along with portability features like Surface Pen storage to have the S Pen close by and a replaceable shoulder strap so you can stay on the go. With a smart design and protection, you can trust the Plasma Series provides heavy-duty protection shielding your tablet from the day while you're working.
- UAG Case for Surface Pro 7+/7/6/5/LTE/4 w/ HS & SS - Plasma White/Grey - back cover for tablet
- Product Type
- Back cover for tablet
- 19.1 cm x 1.91 cm x 25.8 cm
- 290 g
- Grey, white
- Limited lifetime warranty
- Designed For
- Microsoft Surface Pro (Mid 2017), Pro 4, Pro 6, Pro 7, Pro 7+
- 19.1 cm
- 1.91 cm
- 25.8 cm
- 290 g
- Grey, white
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- Protection
- Drop-proof
- Cover Type
- Back cover
- Carrying Strap
- Hand strap, removable shoulder strap
- Additional Compartments
- Surface Pen
- Cover Features
- Stand function
- MIL-STD 810G 516.6
- Max Height of Drop Protection
- 1.2 m
- Lifetime
- Designed For
