Urban Armor Gear Plasma for iPhone 12/12 Pro - Ice
Quicklinx: G5MGWS00 Mfr#: 112353114343
£12.93 ex VAT
£15.51 inc VAT
An excellent showcase of the dedication to superior quality and craftsmanship is the Plasma phone case. Finally, ultra-protection doesn't have to mean ultra-bulky. The Plasma Series has a feather-light composite case that features a hard-outer shell and a soft impact resistant core. The unique shape of the case provides strength while minimizing the size and weight that you usually see from a typical protective case. With the Plasma case you can visibly see the protection, its skid pad corners and strong honeycomb structure and at the same time feel the slim body in your hand.
UAG Rugged Case for iPhone 12/12 Pro 5G [6.1-inch] - Plasma Ice - back cover for mobile phone
Back cover for mobile phone
7.87 cm x 1.22 cm x 15.5 cm
31.2 g
Ice
1-year warranty
Apple iPhone 12, 12 Pro
7.87 cm
1.22 cm
15.5 cm
31.2 g
Ice
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
Shock protection
Cover Type
Back cover
MIL-STD 810G 516.6
1 year
Brand: Urban Armor Gear
Stock Status: In stock
