An excellent showcase of the dedication to superior quality and craftsmanship is the Plasma phone case. Finally, ultra-protection doesn't have to mean ultra-bulky. The Plasma Series has a feather-light composite case that features a hard-outer shell and a soft impact resistant core. The unique shape of the case provides strength while minimizing the size and weight that you usually see from a typical protective case. With the Plasma case you can visibly see the protection, its skid pad corners and strong honeycomb structure and at the same time feel the slim body in your hand.
- UAG Rugged for Case for Apple iPhone SE (2020) - Plasma Ice - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- Screen Size Compatibility
- 4.7"
- Ice
- Designed For
- Apple iPhone SE (2nd generation)
- Package Type
- Retail
- Ice
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- 4.7"
- Protection
- Scratch-resistant, impact protection, drop-proof
- Cover Type
- Back cover
- Shipping Dimensions (WxDxH) / Weight
- 12.07 cm x 1.91 cm x 19.69 cm / 100 g
- MIL-STD 810G 516.6
- Designed For
