Urban Armor Gear products reflect the independent spirit of its designers and represent a dedication to superior quality and craftsmanship. Engineered for the iPad Pro 10.5-inch / iPad Air 10.5-inch, the cases combine light-weight materials in a rugged, low-profile design to provide maximum protection for your iPad. Utilizing a tough yet durable exterior, the iPad case ensures your case won't slip out of your hand in daily use. Oversized ports, tactile buttons, and a smart cover provide maximum usability on your next adventure. Protect your iPad with UAG in three vibrant colors: Magma, Cobalt, and Black. Compatible with iPad Pro 10.5-inch Model Numbers: A1701 & A1709 and iPad Air 10.5-inch (3rd Generation, 2019) Model Numbers: A2152, A2153, A2123, & A2154.
- UAG Rugged Case for iPad Air 10.5-inch / iPad Pro 10.5-inch - Metropolis Black - case for tablet
- Product Type
- Case for tablet
- Screen Size Compatibility
- 10.5"
- 189.7 mm x 19.8 mm x 259.1 mm
- 297.7 g
- Material
- Polyurethane, thermoplastic polyurethane (TPU)
- Black
- 1-year warranty
- Designed For
- Apple 10.5-inch iPad Air (3rd generation); 10.5-inch iPad Pro
- 189.7 mm
- 19.8 mm
- 259.1 mm
- 297.7 g
- Material
- Black
Carrying Case
- Case
- Recommended Use
- For tablet
- 10.5"
- Protection
- Impact protection, drop-proof
- Open Type
- Side
- Additional Compartments
- Apple Pencil
- Cover Features
- Stand function, non-slip grip
- MIL-STD 810G 516.6
- 1 year
- Designed For
- Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro
