UAG's Tempered Glass Screen Shields are engineered to protect your display from scratches and abrasions even in the most demanding environments. The ultra-thin construction delivers precision touch sensitivity and pristine HD surface clarity. A special coating repels natural skin oils; limiting, fingerprints and smudges that can compromise image resolution. Couple the tempered glass screen shields with one of the cases to experience unparalleled protection on all your adventures.
- UAG Tempered Glass Screen Shield for iPad Pro 12.9-inch (Gen 5/4/3, 2021,2020,2018 - screen protector for tablet
- Product Type
- Screen protector - glass
- Intended For
- Tablet
- Screen Size Compatibility
- 12.9"
- Protection
- Scratch-resistant, fingerprint-proof
- Product Material
- Oleophobic coating, tempered glass (9H)
- Thickness
- 0.2 mm
- 1-year warranty
- Designed For
- Apple 12.9-inch iPad Pro (3rd generation, 4th generation, 5th generation)
- Product Type
- Intended For
- Tablet
- 12.9"
- Protection
- Product Material
- Thickness
- 0.2 mm
- 1-year warranty
- Designed For
