Unicol VZWW1 Thin Tiltilng Wall Mount For Screens 33-57"
Quicklinx: 97TDWS00 Mfr#: VZWW1
This mount uses the same tried and trusted methods of wall, stand or ceiling mounting but comes with its own adapters to fit to standard columns or stands.
Unicol Thin VZWW1 mounting kit - for flat panel - black
Mounting kit - wall-mountable
Adjustments
Tilt
Recommended Use
Flat panel
Recommended Display Size
33"-57"
VESA Mounting Interface
200 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 300 mm
Max Load Weight
35 kg
AV Furniture
Mounting kit
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
33"-57"
Adjustments
Tilt
Max Load Weight
35 kg
