Product
Brand
Unicol PZW1 Tilting Wall Bracket For Screens 37-57"
Quicklinx: 97THWS00 Mfr#: PZW1
Imagine you could reach out and with a light touch, tilt your display anywhere through its range to suit your precise viewing angle. The ease of this is possible thanks to the Pozimount tilt counterbalance mechanism. The tilt angle you choose is reliably set or can be changed whenever necessary.
Unicol POZIMOUNT PZW1 - wall mount
Wall mount
Adjustable Width
20-68 cm
Adjustable Height
20-51 cm
Recommended Use
LCD / plasma panel
Recommended Display Size
32"-57"
Flat Panel Mount Interface
200 x 200 mm, 700 x 500 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 600 x 200 mm, 300 x 300 mm, 500 x 500 mm
Max Mounting Pattern Size
765 x 540 mm
Max Load Weight
60 kg
Adjustable Width
20-68 cm
Adjustable Height
20-51 cm
AV Furniture
Wall mount
Mounting Components
Tilt wall mount
Recommended Use
LCD / plasma panel
765 x 540 mm
32"-57"
Max Load Weight
60 kg
Adjustable height, adjustable width
