Ubiquiti UniFi UVC-G3 Network Surveillance Camera
Quicklinx: CK4KWS00 Mfr#: UVC-G3
The UniFi Video Camera is designed for use indoors or outdoors under an overhang. The camera has infrared LEDs with automatic IR cut filter. Accessible from a web browser, the UniFi video interface was designed to be easy to use yet packed with advanced features. The UniFi video interface is incredibly intuitive and loaded with powerful features such as detailed statistical reporting, multiple views, versatile camera settings, advanced analytics, and customizable event recordings.
  • Feature-packed user interface
    Accessible from a web browser, the UniFi Video interface was designed to be easy to use yet packed with advanced features. The UniFi Video interface is incredibly intuitive and loaded with powerful features such as detailed statistical reporting, multiple views, versatile camera settings, advanced analytics, and customizable event recordings.
  • Plug and play installation
    Automatic camera detection in the UniFi Video software makes it easy to install and deploy cameras. UniFi Video Camera settings are integrated into the UniFi Video software. Configure camera settings, reboot the camera, or upgrade the firmware from the UniFI Video interface.
  • Mobile support The UniFi
    Video web interface is accessible on iOS and Android tablets and phones. Camera-Based Motion Detection The UniFi Video cameras handle motion detection instead of the server, relieving the workload on the server and ensuring that compression and noise won't affect motion detection.
  • Additional live views
    Playlists can be created with a configurable live camera feed rotation. Define the cameras you want included in the playlist and how long you want them to appear on the screen before moving on to the next live feed.
  • Disk management features
    UniFi Video has automatic recording management to free up disk space. User-definable disk space and date-based auto purge allow users to keep a set amount of free disk space or automatically delete recordings after a certain number of days. Another storage feature is the ability to map external USB or network storage drives.
  • Cost-effective solution
    Shattering conventional industry thinking, Ubiquiti offers UniFi Video's powerful IP surveillance software at no additional cost. No huge upfront costs, no monthly subscription fees.
Ubiquiti UniFi UVC-G3 - network surveillance camera
Network surveillance camera - fixed - outdoor - weatherproof
Audio
Yes: built-in microphone
Camera Mount Type
Wall mount, ceiling mount, pole mount
7.5 cm x 14 cm x 7.5 cm
300 g
Wired
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Video Modes
1080p
Optical Sensor Type
1/3" - 4 MP
Focal Length Control
Fixed focal
Focal Length
3.6 mm
Lens Iris
F/1.8
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Sharpness control, saturation control, brightness control, Power over Ethernet, contrast control, infrared cut filter, reset button, High Dynamic Range (HDR), noise reduction
1-year warranty
Environmental Parameters (operating)
-30 °C - 70 °C; 20 - 90% (non-condensing) relative humidity
Audio Support
Camera Mount Type
Wired
7.5 cm
14 cm
7.5 cm
300 g
Camera
Colour - Day&Night - fixed - outdoor - weatherproof
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Video Modes
1080p
Infrared LEDs
Digital Video Capture Resolution
1920 x 1080
Frame Rate (max)
RAM
512 MB
Image Sensor
4 MP 1/3"
Lens Construction
Fixed focal
Focal Length
3.6 mm
Lens Iris
F/1.8
Network Interface
Ports
LAN/power
Mounting kit
Power Requirements
PoE
Power injector - external 4 Watt
Ubuntu 12.04, Ubuntu 14.04, Debian Linux 7.0, Microsoft Windows 7 / 8 / 10
Limited warranty - 1 year
-30 °C
70 °C
Relative Humidity (operating)
