The UniFi Video Camera is designed for use indoors or outdoors under an overhang. The camera has infrared LEDs with automatic IR cut filter. Accessible from a web browser, the UniFi video interface was designed to be easy to use yet packed with advanced features. The UniFi video interface is incredibly intuitive and loaded with powerful features such as detailed statistical reporting, multiple views, versatile camera settings, advanced analytics, and customizable event recordings.
Feature-packed user interface
Accessible from a web browser, the UniFi Video interface was designed to be easy to use yet packed with advanced features. The UniFi Video interface is incredibly intuitive and loaded with powerful features such as detailed statistical reporting, multiple views, versatile camera settings, advanced analytics, and customizable event recordings. -
Plug and play installation
Automatic camera detection in the UniFi Video software makes it easy to install and deploy cameras. UniFi Video Camera settings are integrated into the UniFi Video software. Configure camera settings, reboot the camera, or upgrade the firmware from the UniFI Video interface. -
Mobile support The UniFi
Video web interface is accessible on iOS and Android tablets and phones. Camera-Based Motion Detection The UniFi Video cameras handle motion detection instead of the server, relieving the workload on the server and ensuring that compression and noise won't affect motion detection. -
Additional live views
Playlists can be created with a configurable live camera feed rotation. Define the cameras you want included in the playlist and how long you want them to appear on the screen before moving on to the next live feed. -
Disk management features
UniFi Video has automatic recording management to free up disk space. User-definable disk space and date-based auto purge allow users to keep a set amount of free disk space or automatically delete recordings after a certain number of days. Another storage feature is the ability to map external USB or network storage drives. -
Cost-effective solution
Shattering conventional industry thinking, Ubiquiti offers UniFi Video's powerful IP surveillance software at no additional cost. No huge upfront costs, no monthly subscription fees.
- Ubiquiti UniFi UVC-G3 - network surveillance camera
- Network surveillance camera - fixed - outdoor - weatherproof
- Audio
- Yes: built-in microphone
- Camera Mount Type
- Wall mount, ceiling mount, pole mount
- 7.5 cm x 14 cm x 7.5 cm
- 300 g
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Video Modes
- 1080p
- Optical Sensor Type
- 1/3" - 4 MP
- Focal Length Control
- Fixed focal
- Focal Length
- 3.6 mm
- Lens Iris
- F/1.8
- Ethernet 10Base-T/100Base-TX
- Voltage
- PoE
- Sharpness control, saturation control, brightness control, Power over Ethernet, contrast control, infrared cut filter, reset button, High Dynamic Range (HDR), noise reduction
- 1-year warranty
- Environmental Parameters (operating)
- -30 °C - 70 °C; 20 - 90% (non-condensing) relative humidity
- Audio Support
- Camera Mount Type
- Wired
- 7.5 cm
- 14 cm
- 7.5 cm
- 300 g
Camera
- Colour - Day&Night - fixed - outdoor - weatherproof
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 1920 x 1080
- Video Modes
- 1080p
- Infrared LEDs
- Digital Video Capture Resolution
- 1920 x 1080
- Frame Rate (max)
- RAM
- 512 MB
Image Sensor
- 4 MP 1/3"
Lens Construction
- Fixed focal
- Focal Length
- 3.6 mm
- Lens Iris
- F/1.8
- Network Interface
- Ports
- LAN/power
- Included Accessories
- Mounting kit
- Power Requirements
- PoE
- Power Device
- Power injector - external 4 Watt
- OS Required
- Ubuntu 12.04, Ubuntu 14.04, Debian Linux 7.0, Microsoft Windows 7 / 8 / 10
- Limited warranty - 1 year
- -30 °C
- 70 °C
- Relative Humidity (operating)
- 20 - 90% (non-condensing)
