The fast UniFi model with speeds of up to 300 Mbps in the 5 GHz radio band and up to 450 Mbps in the 2.4 GHz radio band. The UAP-Pro offers simultaneous dual-band operation with 2x2 and 3x3 MIMO technology.
- Ubiquiti UniFi UAP-Pro - radio access point - Wi-Fi
- Radio access point
- Packaged Quantity
- 3 (specifications are for single item)
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 5 GHz
- Included Accessories
- PoE injector
- Power Over Ethernet (PoE) Supported
- PoE
- 20 cm x 20 cm x 3.65 cm
- 298 g
- Packaged Quantity
- 20 cm
- 20 cm
- 3.65 cm
- 298 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 750 Mbps
- Frequency Band
- 5 GHz
- Max Range Open Space
- 122 m
- MIMO technology, wall mountable, ceiling mountable
- Encryption Algorithm
- AES, TKIP, WPA2, WPA-PSK, WEP
- IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11i, IEEE 802.11n
Aerial
- Antenna
- Internal
- Antenna Qty
- 5
- 2 x 1000Base-T - RJ-45
- PoE injector
- IC, FCC
- PoE
- 12 Watt
- -10 °C
- 70 °C
- 5 - 80%
