Ubiquiti UniFi UAP PRO 450 Mbps AP/Hotspot 2.4/5Ghz MiMo - 3 Pack
Quicklinx: 9ZNCWS00 Mfr#: UAP-PRO-3
  • IEEE 802.11n
The fast UniFi model with speeds of up to 300 Mbps in the 5 GHz radio band and up to 450 Mbps in the 2.4 GHz radio band. The UAP-Pro offers simultaneous dual-band operation with 2x2 and 3x3 MIMO technology.
Ubiquiti UniFi UAP-Pro - radio access point - Wi-Fi
Radio access point
Packaged Quantity
3 (specifications are for single item)
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
5 GHz
PoE injector
Power Over Ethernet (PoE) Supported
PoE
20 cm x 20 cm x 3.65 cm
298 g
Packaged Quantity
Radio access point
20 cm
20 cm
3.65 cm
298 g
External
Wireless
Data Transfer Rate
750 Mbps
Frequency Band
5 GHz
Max Range Open Space
122 m
MIMO technology, wall mountable, ceiling mountable
Encryption Algorithm
AES, TKIP, WPA2, WPA-PSK, WEP
IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11i, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
5
2 x 1000Base-T - RJ-45
PoE injector
IC, FCC
PoE
12 Watt
-10 °C
70 °C
5 - 80%
