Ubiquiti UniFi UAP Outdoor + Scalable WiFi Access Point
Quicklinx: BGKGWS00 Mfr#: UAP-OUTDOOR +
  • IEEE 802.11n
The weather-resistant case is designed specifically for outdoor installations. Dual, omni-directional antennas on the UAP-Outdoor+ provides 360° wireless coverage.
Ubiquiti UniFi UAP-Outdoor+ - radio access point - Wi-Fi
Radio access point
External - outdoor
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
PoE injector
Power Over Ethernet (PoE) Supported
PoE
8.3 cm x 3.7 cm x 20.5 cm
250 g
Radio access point
Ruggedized Design
Outdoor
8.3 cm
3.7 cm
20.5 cm
250 g
External
Wireless
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
Max Range Open Space
183 m
Power over Ethernet (PoE), VLAN support, MIMO technology, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, pole mountable
Encryption Algorithm
AES, TKIP, WPA2, WPA-PSK, WEP
IEEE 802.1Q, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.11i, IEEE 802.11n
Aerial
Antenna
External detachable
Antenna Qty
2
Directivity
Omni-directional
Gain Level
5 dBi
2 x 100Base-TX - RJ-45
PoE injector
IC, FCC
PoE
8 Watt
-30 °C
65 °C
5 - 95% (non-condensing)
