The UniFi Security Gateway extends the UniFi Enterprise System to provide cost-effective, reliable routing and advanced security for your network.
Integration with UniFi Controller
Bundled at no extra charge, the UniFi Controller software conducts device discovery, provisioning, and management of the UniFi Security Gateway and other UniFi devices through a single, centralized interface. -
Powerful firewall performance
The UniFi Security Gateway offers advanced firewall policies to protect your network and its data. -
Convenient VLAN support
The UniFi Security Gateway can create virtual network segments for security and network traffic management. -
VPN server for secure communications
A site-to-site VPN secures and encrypts private data communications traveling over the Internet. -
QoS for enterprise VoIP
Top QoS priority is assigned to voice/video call traffic for clear calls and lag-free, video streaming.
- Ubiquiti Unifi USG - security appliance
- Security appliance
- Form Factor
- External
- Processor
- 1 x MIPS64 500 MHz
- RAM
- 512 MB
- Flash Memory
- 2 GB
- Ports Qty
- 3
- Data Link Protocol
- Performance
- Forwarding performance (64-byte packet size): 1000000 packets per second , Throughput (512-byte packet size): 3 Gbps
- 13.5 cm x 13.5 cm x 2.83 cm
- 366 g
- 13.5 cm
- 13.5 cm
- 2.83 cm
- 366 g
Processor / Memory / Storage
- Processors Installed
- Max Supported Qty
- 1
- RAM
- 512 MB DDR2 SDRAM
- Flash Memory
- 2 GB
- Form Factor
- External
- Ports Qty
- 3
- Connectivity Technology
- Wired
- Remote Management Protocol
- CLI
- Performance
- Fanless
- 1 x console - RJ-45 , 3 x 1000Base-T - RJ-45
- IC, FCC
- Power Device
- External power adapter
- 7 Watt
- Software Included
- UniFi Controller
- -10 °C
- 45 °C
- 10 - 90% (non-condensing)
