Ubiquiti UniFi AP, 802.11ac db 3x3 MIMO World Ver
Quicklinx: B99BWS00 Mfr#: UAP-AC-Outdoor
  • IEEE 802.11n
The UniFi AP-AC Outdoor can be mounted seamlessly on any wall or pole (mounting kits included). The LED indicator simplifies deployment and configuration. The UniFi AP-AC Outdoor supports up to 1300 Mbps in the 5 GHz band and up to 450 Mbps in the 2.4 GHz band. The UniFi AP-AC Outdoor supports 3x3 MIMO technology in the 5 and 2.4 GHz radio bands.
  • Sleek industrial design of the fastest outdoor AP
  • Breakthrough hardware performance
  • Powerful 3x3 MIMO
  • Built to last outdoors
    The durable, weatherproof case withstands outdoor conditions, including wind, rain and snow.
  • Simultaneous dual-band Wi-Fi
    The UniFi AP-AC Outdoor supports simultaneous operation in the 5 and 2.4 GHz radio bands.
  • Gigabit Ethernet & PoE+
    Capable of gigabit speeds, the UniFi AP-AC Outdoor can be powered by a PoE+, 802.3at compliant switch or the included 48V PoE Adapter.
  • Scalability for thousands
    With its software-based capabilities, the UniFi virtual control plane allows for unlimited scalability under one centralized controller.
Ubiquiti UniFi UAP-AC Outdoor - radio access point - Wi-Fi 5
Radio access point
External - outdoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
PoE injector
Power Over Ethernet (PoE) Supported
PoE+
18 cm x 6.5 cm x 34 cm
1.55 kg
Radio access point
Ruggedized Design
Outdoor
18 cm
6.5 cm
34 cm
1.55 kg
External
Wireless
Data Transfer Rate
1300 Mbps
Frequency Band
2.4 GHz, 5 GHz
Max Range Open Space
183 m
Power over Ethernet (PoE), VLAN support, firmware upgradable, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, PoE+, pole mountable, 3T3R MIMO technology
Encryption Algorithm
AES, TKIP, WPA, WPA2, WPA-PSK, WEP
IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11i, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
2
Directivity
Omni-directional
Gain Level
5 dBi
2 x 1000Base-T - RJ-45
PoE injector
IC, FCC
PoE+
22 Watt
-30 °C
60 °C
5 - 80% (non-condensing)
