The UniFi AP-AC Outdoor can be mounted seamlessly on any wall or pole (mounting kits included). The LED indicator simplifies deployment and configuration. The UniFi AP-AC Outdoor supports up to 1300 Mbps in the 5 GHz band and up to 450 Mbps in the 2.4 GHz band. The UniFi AP-AC Outdoor supports 3x3 MIMO technology in the 5 and 2.4 GHz radio bands.
Sleek industrial design of the fastest outdoor AP
The UniFi AP-AC Outdoor can be mounted seamlessly on any wall or pole (mounting kits included). The LED indicator simplifies deployment and configuration. -
Breakthrough hardware performance
The UniFi AP-AC Outdoor supports up to 1300 Mbps in the 5 GHz band and up to 450 Mbps in the 2.4 GHz band. -
Powerful 3x3 MIMO
The UniFi AP-AC Outdoor supports 3x3 MIMO technology in the 5 and 2.4 GHz radio bands. -
Built to last outdoors
The durable, weatherproof case withstands outdoor conditions, including wind, rain and snow. -
Simultaneous dual-band Wi-Fi
The UniFi AP-AC Outdoor supports simultaneous operation in the 5 and 2.4 GHz radio bands. -
Gigabit Ethernet & PoE+
Capable of gigabit speeds, the UniFi AP-AC Outdoor can be powered by a PoE+, 802.3at compliant switch or the included 48V PoE Adapter. -
Scalability for thousands
With its software-based capabilities, the UniFi virtual control plane allows for unlimited scalability under one centralized controller.
- Ubiquiti UniFi UAP-AC Outdoor - radio access point - Wi-Fi 5
- Radio access point
- Form Factor
- External - outdoor
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Included Accessories
- PoE injector
- Power Over Ethernet (PoE) Supported
- PoE+
- 18 cm x 6.5 cm x 34 cm
- 1.55 kg
- Ruggedized Design
- Outdoor
- 18 cm
- 6.5 cm
- 34 cm
- 1.55 kg
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1300 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Max Range Open Space
- 183 m
- Power over Ethernet (PoE), VLAN support, firmware upgradable, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, PoE+, pole mountable, 3T3R MIMO technology
- Encryption Algorithm
- AES, TKIP, WPA, WPA2, WPA-PSK, WEP
- IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11i, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
- Antenna
- Internal
- Antenna Qty
- 2
- Directivity
- Omni-directional
- Gain Level
- 5 dBi
- 2 x 1000Base-T - RJ-45
- PoE injector
- IC, FCC
- PoE+
- 22 Watt
- -30 °C
- 60 °C
- 5 - 80% (non-condensing)
