Ubiquiti UniFi Access Point
Quicklinx: C3SPWS00 Mfr#: UAP
  • IEEE 802.11n
UniFi is a revolutionary Wi-Fi system which combines carrier class performance, unlimited scalability, disruptive pricing, and a virtual management controller. UniFi Access Points feature the latest in Wi-Fi 802.11n MIMO technology - capable of 300 Mbps speeds with ranges up to 500 ft.
Ubiquiti UniFi AP - radio access point Wi-Fi
Radio access point
External - indoor
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Power Over Ethernet (PoE) Supported
PoE
20 cm x 20 cm x 3.65 cm
290 g
Radio access point
Ruggedized Design
Indoor
20 cm
20 cm
3.65 cm
290 g
External
Wireless
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
Max Range Open Space
122 m
VLAN support, firmware upgradable, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, 2T2R MIMO technology, ceiling mountable
Encryption Algorithm
AES, TKIP, WPA2, WPA-PSK
IEEE 802.1Q, IEEE 802.11b, IEEE 802.11g, IEEE 802.11i, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
2
1 x 100Base-TX - RJ-45
IC, FCC
PoE
4 Watt
Software Included
Drivers & Utilities
-10 °C
70 °C
5 - 80%
