Ubiquiti Rocket ac R5AC-PTP Radio Access Point
Quicklinx: C8QPWS00 Mfr#: R5AC-PTP
Featuring airMAX ac technology, the Rocket5ac PTP is ideal for Point-to-Point (PtP) links requiring maximum performance.
  • Performance breakthrough
    airMAX ac products offer improved latency, noise immunity, scalability and significantly increased throughput performance.
  • Superior processing
    Ubiquiti's airMAX engine with custom IC dramatically improves TDMA latency and network scalability. The custom silicon provides hardware acceleration capabilities to the airMAX scheduler, to support the high data rates and dense modulation used in airMAX ac technology.
  • Plug and play integration
    The airMAX ac antennas feature significant advances in beam and energy isolation performance for increased capacity of airMAX networks.
Ubiquiti Rocket ac R5AC-PTP - radio access point - AirMax ac
Radio access point
External - outdoor
1 x Atheros MIPS 74KC 720 MHz
RAM
128 MB
Flash Memory
16 MB
AirMax ac
Frequency Band
5 GHz
Power Over Ethernet (PoE) Supported
PoE
19.85 cm x 8.64 cm x 4.41 cm
295 g
Radio access point
Ruggedized Design
Outdoor
19.85 cm
8.64 cm
4.41 cm
295 g
Processor / Memory / Storage
Processors Installed
Max Supported Qty
1
RAM
128 MB SDRAM
Flash Memory
16 MB
External
Wireless
AirMax ac
Frequency Band
5 GHz
Status Indicators
Power, LAN
MIMO technology
Encryption Algorithm
AES, WPA2
2 x aerial - RP-SMA , 1 x 1000Base-T (PoE) - RJ-45
IC, FCC
PoE
8.5 Watt
-40 °C
80 °C
5 - 95% (non-condensing)
