Product
Ubiquiti EdgeSwitch 24port 250W
Quicklinx: C00ZWS00 Mfr#: ES-24-250W
Type: Gigabit Ethernet
Ports: 24
Managed: Yes
POE: PoE+
Stock Status: Clearance
Hurry, only 1 left in stock!
£344.87 ex VAT
£413.84 inc VAT
Express delivery Order within the next 12 hours for delivery tomorrow
EdgeSwitch delivers robust performance, PoE+ support and intelligent switching for growing networks.
  • Powerful enterprise switch models
    The EdgeSwitch delivers the forwarding capacity to simultaneously process traffic on all ports at line rate without any packet loss.
  • Enterprise-class features
    The EdgeSwitch supports an extensive suite of advanced Layer-2 switching features and protocols, and also provides Layer-3 routing capability.
  • Optical fiber backhaul
    Two SFP ports support uplinks of up to 1 Gbps. For high-capacity uplinks, each 48-port model includes two SFP+ ports for uplinks of up to 10 Gbps.
  • Convenient PoE+ support
    The EdgeSwitch features auto-sensing IEEE 802.3af/at and 24V passive PoE to power multiple devices on the network.
  • Breakthrough value
    The EdgeSwitch provides top price/performance value: a full-featured, enterprise-class switch.
  • Advanced UI
    The comprehensive UI is easy to learn and allows administrators to configure and monitor features in a graphical user interface. For advanced users, a Command-Line Interface (CLI) is available through telnet and SSH.
Ubiquiti EdgeSwitch 24 - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L3 - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE+) + 2 x Gigabit SFP
Power Over Ethernet (PoE)
PoE+
Performance
Non-blocking switching capacity: 26 Gbps , Switching capacity: 52 Gbps , Forwarding performance: 38.69 Mpps
VLANs supported: 255 , ACL rules: 100 , LAG groups: 6
MAC Address Table Size
8K entries
Jumbo Frame Support
Routing Protocol
Static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, SNMP 3, HTTP, SSH-2, CLI
Flow control, BOOTP support, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, Uni-Directional Link Detection (UDLD), LLDP support, Link Aggregation Control Protocol (LACP), Dynamic VLAN Support (GVRP), Class of Service (CoS), Generic Attribute Registration Protocol (GARP)
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ak, IEEE 802.1ab (LLDP), IEEE 802.3at
AC 120/230 V (50 - 60 Hz)
48.504 cm x 28.56 cm x 4.445 cm
3.7 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
Performance
8K entries
Jumbo Frame Support
Routing Protocol
Status Indicators
Port transmission speed, PoE, link/activity
24 x 1000Base-T RJ-45 PoE+ - 34.2 W , 2 x 1000Base-X SFP
Internal power supply
250 Watt
IC, FCC, ETSI 300 019
48.504 cm
28.56 cm
4.445 cm
3.7 kg
-5 °C
5 - 95% (non-condensing)
Ports: 24
Managed: Yes
POE: PoE+
Brand: Ubiquiti
Price Range Ex VAT: 300 - 500
