Product
Ubiquiti airMAX NanoBeam NBE-5AC-19 19dBi AC (5Ghz)
Quicklinx: BQTVWS00 Mfr#: NBE-5AC-19
Incorporating great industrial design with proprietary airMAX ac technology, the NanoBeam ac is ideal for CPE deployments requiring maximum performance from the small footprint.
  • Performance breakthrough
    airMAX ac products offer improved latency, noise immunity, scalability and significantly increased throughput performance.
  • Superior processing
    Ubiquiti's airMAX engine with custom IC dramatically improves TDMA latency and network scalability. The custom silicon provides hardware acceleration capabilities to the airMAX scheduler, to support the high data rates and dense modulation used in airMAX ac technology.
  • Incredible antenna "beam" performance
    The form factor of the NanoBeam ac features the high gain for its size. The NanoBeam ac's excellent beam directivity provides amazing performance in high-noise environments.
  • Plug and play installation
    The NanoBeam ac mounts to a variety of surfaces including poles or walls, and offers the freedom of three-axis alignment.
Ubiquiti NanoBeam ac NBE-5AC-19 - wireless bridge
Wireless bridge
External - outdoor
1 x Atheros MIPS 74KC 720 MHz
RAM
128 MB
Flash Memory
8 MB
AirMax ac
Frequency Band
5 GHz
Pole mount, wall mounting kit
Power Over Ethernet (PoE) Supported
PoE
18.9 cm x 12.5 cm x 18.9 cm
530 g
Wireless bridge
Ruggedized Design
Outdoor
18.9 cm
12.5 cm
18.9 cm
530 g
Processor / Memory / Storage
Processors Installed
Max Supported Qty
1
RAM
128 MB DDR2 SDRAM
Flash Memory
8 MB
External
Wireless
AirMax ac
Frequency Band
5 GHz
Status Indicators
Power, WLAN, LAN
24KV ESD Protector
Aerial
Antenna
Internal
Gain Level
19 dBi
1 x 100Base-TX - RJ-45
IC, FCC, RoHS, IEC 60068-2-6, IEC 60068-2-14, ETSI 300 019, MIL-STD 810G 506.5, IEC 60068-2-11
PoE
External power adapter
8 Watt
OS Provided
AirOS
-40 °C
70 °C
5 - 95% (non-condensing)
