Raise your game on Xbox One with the Ear Force XO SEVEN Pro featuring the Ear Force Headset Audio Controller Plus which adds Superhuman Hearing, Game and Mic Presets, Mic Monitoring and more! Whether you are on the MLG Pro Circuit or just want to be, the XO SEVEN Pro has the tournament-grade durability, amazing sound quality and features you need to win. Plus, with the included Mobile Cable with In-Line Mic, the XO SEVEN Pro will be your headset of choice for mobile calls, music and gaming on the go.
Astounding sound quality
Amazing sound quality from premium 50mm Neodymium Speakers tuned for Xbox One. -
Ear force XO headset audio controller plus
All-new "Plus" features audio customization tools like Superhuman Hearing Mode and Game and Mic Presets to go with Mic Monitoring and game and chat volume controls. -
Superhuman hearing mode
Use Superhuman Hearing Mode to pinpoint quiet audio cues like enemy footsteps and weapon reloads. -
Game and mic presets
Selectable game presets to customize your sound and environmental mic presets you can set based on room noise levels. -
Stop shouting
Use Variable Mic Monitoring to adjust the level of your own voice in the headset - so you don't have to shout! -
Total control chat
The Ear Force Headset Audio Controller Plus also features game and chat volume mix, master volume and mic mute controls. -
Built to compete
Tournament-grade headset durability and materials like memory foam ear cushions for comfort and noise-isolation. -
Mobile versatility
The included Mobile Cable with In-Line Mic means the XO SEVEN Pro can be used for phone calls without the boom mic. -
For all your audio needs
XO SEVEN Pro isn't just great for games. Enjoy your favorite movies and TV shows with high quality sound. Then crank up your tunes from music services like Xbox Music or Skype with friends!
- Turtle Beach Ear Force XO SEVEN Pro - headset
- Product Type
- Headset - wired
- Recommended Use
- Game console
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Microphone
- Boom
- Microphone Operation Mode
- Mono
- Product Type
- Headset - wired
- Recommended Use
- Game console
Audio Output
- Full size
- Wired
- Sound Output Mode
- Stereo
Microphone
- Boom
- Mono
