Trust Oxxtron 1000VA UPS
Quicklinx: 96J1WS00 Mfr#: 17680
A lightning strike or a broken power cable can put an end to your work on the computer just like that. Prevent the loss of important data with the latest UPS security device from Trust. A power failure can have disastrous consequences for your digital data. After hours of work at the computer, having to start all over again doesn't bear thinking about. Trust prevents this scenario with a series of new UPS devices. The new Oxxtron UPS from Trust is a so-called uninterrupted power supply which ensures that electronic devices don't break down during a power failure. The Oxxtron UPS is available in three versions: 1000VA, 1300VA and 1500VA and also protects your equipment against overload and short circuit. Connect your PC, monitor or other expensive equipment to one of the ports and you don't have to worry any more about losing data.
The new Trust Oxxtron UPS from Trust is a so-called uninterrupted power supply which ensures that electronic devices don't break down during a power failure. The Oxxtron UPS is available in three versions: 1000VA, 1300VA and 1500VA and also protects your equipment against overload and short circuit. Connect your PC, monitor or other expensive equipment to one of the ports and you don't have to worry any more about losing data.
Trust Oxxtron 1000VA UPS - UPS - 1000 VA
UPS - external
Power Capacity
1000 VA
Output connectors
3 x power (UPS and surge)
UPS - external
Power Capacity
1000 VA
Surge Suppression
2 x power cable
Equipment Protection Value
20000 Euros
Audible alarm, Automatic Voltage Regulation (AVR), overload protection, short-circuit protection
