Tripp Lite TRIPPLITE 2200VA 19-INCH RACKMOUNT SMARTPRO UPS (8 C13 Outle
Quicklinx: 83FXWS00 Mfr#: SMX2200XLRT2U
Type: UPS
Power Rating: 1920Watt
Hurry, only 3 left in stock!
£601.82 ex VAT
£722.18 inc VAT
Tripp Lite SmartPro Line Interactive UPS with enhanced LCD interface offers network-grade power protection for critical server, network and telecommunications equipment. Line Interactive Uninterruptible Power Supply (UPS) with built-in Auto-Voltage Regulation (AVR) actively corrects brownouts and overvoltages back to usable levels while maintaining a full battery charge in case of power failure. Tripp Lite's unique configuration excels in exceptionally poor-power environments with two separate levels of voltage boost to correct both slight undervoltages and severe brownout conditions. Interactive LCD interface reports UPS operating mode, detailed UPS and site-power data, plus enables a variety of UPS setup and configuration options.
Super-fast switchover from line to battery power occurs within milliseconds to maintain operation of connected equipment without interruption or reboot. 98% line-mode efficiency offers reduced heat emissions and operating costs. Network management interfaces support communications via USB, RS-232 and optional SNMPWEBCARD network interface. HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X. Network communications ports enable detailed monitoring of equipment load levels, self-test data and utility power conditions. Switched output load banks enable scheduled and real-time remote reboot and load shedding of select outlets.
Tripp Lite UPS Smart 2200VA 1920W Rackmount AVR 230V Pure Sine Wave C13 2U - UPS - 1920 Watt - 2200 VA
UPS - external
Rack Size
19" - 2U
27.5 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 220/230/240 V + 8% / - 19%
Power Capacity
1920 Watt / 2200 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
8 x power IEC 60320 C13
Lead Acid expandable
Battery Form Factor
Internal
Run Time (Up To)
5 min at full load
Attractive black
44.5 cm x 48.3 cm x 9 cm
UPS - external
Battery Enclosure Type
Internal
Height (Rack Units)
2U
Rack Size
19"
Attractive black
UPS Technology
Line interactive
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 158 - 290 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 220/230/240 V + 8% / - 19% - 50/60 Hz
Power Capacity
1920 Watt / 2200 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
350 Joules
Circuit Protection
Circuit breaker
Expandable
Lead Acid
Voltage Provided
48 V
Run Time (Up To)
5 min at full load
Recharge Time
4 hours
1 x management (USB) - 4 pin USB Type B , 1 x management (RS-232) - 9 pin D-Sub (DB-9)
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
3 x power cable - external
Audible alarm, emergency power off, Automatic Voltage Regulation (AVR), LED indicators
FCC Class A certified, TUV GS, GOST, SASO, RoHS
Software Included
TrippLite PowerAlert
0 - 95%
44.5 cm
48.3 cm
9 cm
27.5 kg
Shipping Width
59.5 cm
Shipping Depth
51 cm
Shipping Height
23 cm
Shipping Weight
32.4 kg
Type: UPS
Brand: Tripp Lite
Price Range Ex VAT: 500 - 750
