Product
Tripp Lite SMX1200XLHG Medical Grade 1000VA 230V/750 Watt
Quicklinx: CPGYWS00 Mfr#: SMX1200XLHG
Tripp Lite’s SMX1200XLHG medical-grade UPS system provides dependable battery backup and is fully compliant with UL 60601-1 regulations when plugged into a hospital-grade outlet, making it ideal for use in patient-care vicinities. The 1kVA/750W capacity provides up to 27.5 minutes of runtime for a half load, or 11 minutes for a full load so you can work through short power failures and perform an orderly system shutdown in a prolonged blackout.
Built-in line-interactive voltage regulation corrects brownouts as low as 155V and overvoltages as high as 274V to normal 230V nominal output, without drawing battery power. The SMX1200XLHG’s built-in isolation transformer with Faraday shield offers full isolation and removes common mode noise while maintaining full AC surge suppression in all modes. Cumulative leakage current of all connected equipment is less than 100 microamps.
This UPS system features six IEC320 C13 hospital-grade outlets and has a hospital-grade IEC320 C14 plug on a 15 cm (6 in.) dongle. All six outlets provide both backup protection and surge protection, rated to 340 joules.
The SMX1200XLHG also features diagnostic LEDs, as well as a USB port and a DB9 serial port that work with Tripp Lite’s included PowerAlert software for safe, unattended system shutdown and file saves in the event of a prolonged power failure.
Tripp Lite UPS Smart 1000VA 750W Tower Medical AVR 230V C13 - UPS - 750 Watt - 1000 VA
UPS - external
20.7 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V + 8% / - 18%
Power Capacity
750 Watt / 1000 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
6 x power IEC 60320 C13
Battery Form Factor
Internal
Run Time (Up To)
11 min at full load
RS-232, USB
Attractive grey
19 cm x 23.1 cm x 32.3 cm
2 years warranty
UPS - external
Battery Enclosure Type
Internal
Attractive grey
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 155 - 274 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V + 8% / - 18% - 50/60 Hz
Power Capacity
750 Watt / 1000 VA
Surge Suppression
Surge Energy Rating
340 Joules
Voltage Provided
36 V
Run Time (Up To)
11 min at full load
Recharge Time
4.5 hours
Remote Management Interface
RS-232, USB
1 x management (USB) - 4 pin USB Type B , 1 x management - 9 pin D-Sub (DB-9)
Power cable - integrated - 15 cm , USB cable - external , Serial cable - external
Audible alarm, voltage monitoring, noise filtering, overload protection
IEC 60601-1-1
Software Included
TrippLite PowerAlert
0 - 95%
19 cm
23.1 cm
32.3 cm
20.7 kg
Shipping Width
31 cm
Shipping Depth
34 cm
Shipping Height
47 cm
Shipping Weight
22 kg
