Product
Brand
Tripp Lite 10Gb Multimode Duplex 50/125 LSZH Aqua Fiber Patch Cable 2m
Quicklinx: C7LHWS00 Mfr#: N820-02M
Tripp Lite introduces its new OM3 Laser-Optimized Multimode Fiber (LOMMF) "Aqua" cables, for use with 10Gb Ethernet applications. These new technology, 50/125um, LC/LC Fiber Optic cables, provide nearly three times the bandwidth over conventional 62.5um multimode fiber, with performance rivaling that of Single mode cable, at a much reduced cost. LOMMF cable allows 10Gb serial transmission over extended distances in the 850nm wavelength window, where low-cost Vertical Cavity Surface Emitting Lasers (VCSELs) enable a cost-effective, high-bandwidth solution. LOMMF is ideally suited for LAN's, SAN's, and high-speed parallel interconnects for head-ends, central offices, and data centers.
Tripp Lite 2M 10Gb Duplex Multimode 50/125 OM3 LSZH Fiber Patch Cable LC/LC Aqua 2 Meters - patch cable - 1.83 m - aqua
Patch cable - OM3
Fibre optic
Type of Fibre Optics
Multimode
Halogen-free, Laser-optimized multimode fibre (LOMMF)
Length
1.83 m
Core / Cladding Diameter
50 / 125 micron
Connector
2 x LC multi-mode - male
Connector (Second End)
Aqua
Network Cable Type
Patch cable - OM3
Fibre optic
Multimode
Jacket Material
Low Smoke Zero Halogen (LSZH)
Fibre Qty
2
50 / 125 micron
Length
1.83 m
Aqua
Connector
RoHS
