TRENDnet USB to 10/100Mbps Adapter
Quicklinx: 7ZMYWS00 Mfr#: TU2-ET100
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet
Form Factor: External
Compatibility: PC
Type: Network adapter
More than 50 in stock
£10.23 ex VAT
£12.27 inc VAT
The TU2-ET100 is a high speed USB network adapter. It allows you to instantly connect to a 10/100Mbps network from a USB enabled desktop or notebook PC. Compliant with the USB 2.0 standard and backwards compatible with the USB 1.0 and 1.1, the TU2-ET100 features 480Mbps throughput that fully supports 100Mbps connection. You can instantly add network capability for sharing files and printers between PCs for your home or office. Use the TU2-ET100 to gain access to broadband Internet and explore valuable resources on the Web.
TRENDnet TU2-ET100 - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
Ports
10/100 Ethernet
8 cm x 5.3 cm x 2.2 cm
68 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
IEEE 802.3, IEEE 802.3u
Microsoft Windows XP, Microsoft Windows 98/ME/2000
5-year warranty
Network adapter
External
USB 2.0
Ports
10/100 Ethernet
Wired
Cabling Type
Data Transfer Rate
100 Mbps
Status Indicators
Transmit, receive, link/activity
Full duplex capability, auto-sensing per device
1 x 100Base-TX - RJ-45 - female
1 x USB cable (external)
Plug and Play, VCCI
Software Included
Drivers & Utilities
8 cm
5.3 cm
2.2 cm
68 g
Limited warranty - 5 years
65 °C
10 - 90%
Protocol: Ethernet
Protocol: Fast Ethernet
Compatibility: PC
Brand: TRENDnet
Price Range Ex VAT: 0 - 50
