Your basket is empty
TRENDnet USB 3.0 to Gigabit Adapter & USB Hub
Quicklinx: 9YP5WS00 Mfr#: TU3-ETG
Wired / Wireless: Wired
Protocol: Gigabit Ethernet
Form Factor: External
Compatibility: PC
Type: Network adapter
8 in stock
£18.04 ex VAT
£21.64 inc VAT
Standard delivery Delivered within 3-5 working days
TRENDnet's compact USB 3.0 to Gigabit Ethernet adapter, model TU3-ETG, and quickly adds a Gigabit Ethernet port to a Windows or Mac computer. A SuperSpeed USB 3.0 port supports Full Duplex 2 Gbps transfer speeds. The TU3-ETG is compatible with older USB 2.0 and 1.1 ports.
TRENDnet TU3-ETG - network adapter
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
7.2 cm x 2.5 cm x 1.5 cm
25 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
2 Gbps
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, USB 1.1, USB 2.0, USB 3.0, IEEE 802.3az
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Apple MacOS X 10.6 - 10.8
2 years warranty
Network adapter
External
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
Wired
Cabling Type
Data Transfer Rate
2 Gbps
Full duplex capability, wake on LAN (WOL), GREENnet technology, USB powered
1 x 1000Base-T - RJ-45
FCC
1.3 Watt
Software Included
Drivers & Utilities
7.2 cm
2.5 cm
1.5 cm
25 g
0 - 90% (non-condensing)
Compatibility: PC
Brand: TRENDnet
Price Range Ex VAT: 0 - 50
