TRENDnet TV-IP762IC HD Wireless Day/Night Cloud Camera
Quicklinx: 97FJWS00 Mfr#: TV-IP762IC
The Wireless HD Day/Night Cloud Camera, model TV-IP762IC, takes the work out of viewing HD video over the internet. After a brief installation, simply open a web browser and login from any internet connection to view and manage this camera. The free TRENDnet CloudView App brings live video to Apple® and Android™ mobile devices. Night vision provides surveillance in complete darkness.
Easy Setup
Complete the initial setup in under 3 minutes in order to view video remotely
HD Video
Experience high definition 720p HD video quality
Night Vision
Night vision up to 5 meters (16 ft.) in complete darkness
Digital Zoom
Zoom in by a factor of four
Motion Detection Emails
Receive snapshots and video clips (up to 15 seconds) of motion via email
Mounting Bracket
Mounting bracket supports upside down installation
Two-Way Audio
Hear sounds from the camera (install a third party speaker for two-way audio)
Storage
Store video to a network storage device or Micro SD card (up to 32 GB sold separately)
Free Apps
See live video on a mobile device with free Apple® and Android™ apps
Complimentary Software
Complimentary pro-grade software to manage up to 32 TRENDnet cameras
Automatic Updates
Convenient automatic firmware updates
  • Easy setup
    Complete the initial setup in under 3 minutes in order to view video remotely.
  • HD video
    Experience high definition 720p HD video quality.
  • Night vision
    Night vision up to 5 meters (16 feet) in complete darkness.
  • Digital zoom
    Zoom in by a factor of four.
  • Motion detection emails
    Receive snapshots and video clips (up to 15 seconds) of motion via email.
  • Mounting bracket
    Mounting bracket supports upside down installation.
  • Two-way audio
    Hear sounds from the camera (install a third party speaker for two-way audio).
TRENDnet TV IP762IC HD Wireless Day/Night Cloud Camera - network CCTV camera
Network CCTV camera - fixed
Camera
Colour - Day&Night
Max Resolution
1280 x 720
Wired, wireless
Frame Rate
30 frames per second
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Audio
Yes : two-way audio capability
Optical Sensor Type
CMOS - 1/4"
Minimum Illumination
0 lux - IR - F2.0 , 0.5 lux - colour - F2.0
Focal Length Control
Fixed focal
Focal Length
3.35 mm
White balance, saturation control, brightness control, contrast control, e-mail alerts, image flip, image mirror, Motion Detection Technology, microSD card slot, built-in IR illuminator, hue control, upgradable firmware, Wi-Fi Protected Setup (WPS), night mode control, ONVIF V2.2 (Profile S) support, reset button
Environmental Parameters (operating)
0 °C - 40 °C ; 0 - 85% (non-condensing) relative humidity
6.2 cm x 3.5 cm x 10.3 cm
85 g
Network CCTV camera
Audio Support
Wired, wireless
6.2 cm
3.5 cm
10.3 cm
85 g
Camera
Colour - Day&Night - fixed
Digital Video Format
MPEG-4, H.264
Max Digital Video Resolution
1280 x 720
Digital Zoom
4
Video Capture
1280 x 720 @ 30 fps
Supported Image Formats
JPEG
Still Image Capture Resolution
1280 x 720
Image Sensor
CMOS 1/4"
Lens Construction
Fixed focal
Focal Length
3.35 mm
Horizontal Field of View (degree)
60
Vertical Field of View (degree)
40
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, UPnP, IPv4, IPv6, RTCP, PPPoE, Samba, 3GPP/ISMA
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x microphone - input , 1 x audio - output - mini-phone 3.5mm
Mounting bracket
1 x network cable - external - 1.5 m
Power adapter - external AC 120/230 V ( 50/60 Hz ) 5 Watt
Software Included
Drivers & Utilities
Microsoft Windows Server 2003, Microsoft Windows Vista / XP, Microsoft Windows Server 2008, Android, Apple iOS, Microsoft Windows 7 / Windows 8
Relative Humidity (operating)
