The Wireless HD Day/Night Cloud Camera, model TV-IP762IC, takes the work out of viewing HD video over the internet. After a brief installation, simply open a web browser and login from any internet connection to view and manage this camera. The free TRENDnet CloudView App brings live video to Apple® and Android™ mobile devices. Night vision provides surveillance in complete darkness.
Easy Setup
Complete the initial setup in under 3 minutes in order to view video remotely
HD Video
Experience high definition 720p HD video quality
Night Vision
Night vision up to 5 meters (16 ft.) in complete darkness
Digital Zoom
Zoom in by a factor of four
Motion Detection Emails
Receive snapshots and video clips (up to 15 seconds) of motion via email
Mounting Bracket
Mounting bracket supports upside down installation
Two-Way Audio
Hear sounds from the camera (install a third party speaker for two-way audio)
Storage
Store video to a network storage device or Micro SD card (up to 32 GB sold separately)
Free Apps
See live video on a mobile device with free Apple® and Android™ apps
Complimentary Software
Complimentary pro-grade software to manage up to 32 TRENDnet cameras
Automatic Updates
Convenient automatic firmware updates
Easy setup
Complete the initial setup in under 3 minutes in order to view video remotely. -
HD video
Experience high definition 720p HD video quality. -
Night vision
Night vision up to 5 meters (16 feet) in complete darkness. -
Digital zoom
Zoom in by a factor of four. -
Motion detection emails
Receive snapshots and video clips (up to 15 seconds) of motion via email. -
Mounting bracket
Mounting bracket supports upside down installation. -
Two-way audio
Hear sounds from the camera (install a third party speaker for two-way audio).
- TRENDnet TV IP762IC HD Wireless Day/Night Cloud Camera - network CCTV camera
- Network CCTV camera - fixed
- Camera
- Colour - Day&Night
- Max Resolution
- 1280 x 720
- Connectivity Technology
- Wired, wireless
- Frame Rate
- 30 frames per second
- Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Audio
- Yes : two-way audio capability
- Optical Sensor Type
- CMOS - 1/4"
- Minimum Illumination
- 0 lux - IR - F2.0 , 0.5 lux - colour - F2.0
- Focal Length Control
- Fixed focal
- Focal Length
- 3.35 mm
- White balance, saturation control, brightness control, contrast control, e-mail alerts, image flip, image mirror, Motion Detection Technology, microSD card slot, built-in IR illuminator, hue control, upgradable firmware, Wi-Fi Protected Setup (WPS), night mode control, ONVIF V2.2 (Profile S) support, reset button
- Environmental Parameters (operating)
- 0 °C - 40 °C ; 0 - 85% (non-condensing) relative humidity
- 6.2 cm x 3.5 cm x 10.3 cm
- 85 g
- Audio Support
- Wired, wireless
- 6.2 cm
- 3.5 cm
- 10.3 cm
- 85 g
Camera
- Colour - Day&Night - fixed
- Digital Video Format
- MPEG-4, H.264
- Max Digital Video Resolution
- 1280 x 720
- Digital Zoom
- 4
- Video Capture
- 1280 x 720 @ 30 fps
- Supported Image Formats
- JPEG
- Still Image Capture Resolution
- 1280 x 720
Image Sensor
- CMOS 1/4"
Lens Construction
- Fixed focal
- Focal Length
- 3.35 mm
- Horizontal Field of View (degree)
- 60
- Vertical Field of View (degree)
- 40
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, UPnP, IPv4, IPv6, RTCP, PPPoE, Samba, 3GPP/ISMA
- 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x microphone - input , 1 x audio - output - mini-phone 3.5mm
- Included Accessories
- Mounting bracket
- Cables Included
- 1 x network cable - external - 1.5 m
- Power Device
- Power adapter - external AC 120/230 V ( 50/60 Hz ) 5 Watt
- Software Included
- Drivers & Utilities
- OS Required
- Microsoft Windows Server 2003, Microsoft Windows Vista / XP, Microsoft Windows Server 2008, Android, Apple iOS, Microsoft Windows 7 / Windows 8
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 0 - 85% (non-condensing)
