TRENDnet TV-IP743SIC WiFi Baby Cam
Quicklinx: 9Q64WS00 Mfr#: TV-IP743SIC
£25.73 ex VAT
£30.87 inc VAT
The compact camera has a convenient adjustable base and comes with an articulated wall mounting bracket for wall installations. Night vision is a tremendous advantage. The TV-IP743SIC's infrared night vision provides visibility in complete darkness for distances of up to 5 meters (16 ft.). Users can also program the camera to email video clips of detected motion or sound activities and it has as built in speaker and microphone for two way audio communications.
TRENDnet's WiFi Baby Cam, model TV-IP743SIC, allows you to monitor your baby from any internet connection. After a brief installation, simply open a web browser or app to view live video on your mobile devices, tablets, and computers. TRENDnet's free CloudView app brings live video to Apple® and Android™ mobile devices. Hear and comfort your baby with the built in microphone and speaker. See your baby in complete darkness with night vision (5 meters, 16 ft.). Setup motion and sound detection to receive video clips via email.
Easy guided setup
Live video to your mobile devices, tablets, and computers
See baby in complete darkness with night vision (5 meters, 16 ft.)
Receive motion and sound detection video clips via email
Free mobile app and cloud service
Play soothing songs
Requires a wireless network
Easy Setup
Quick intuitive guided installation
Remote Monitoring
Live video on your mobile devices, tablets, and computers from any internet connection
Two-Way Audio
Night Vision
See your baby in complete darkness with night vision (5 m, 16 ft.)
Free App
See live video on a mobile device with free Apple® and Android™ apps
Motion and Sound Detection Emails
Mounting Base
Adjustable mounting base for flat and vertical surfaces
Digital Zoom
Zoom in by a factor of four
Recording
Record video to a remote storage device
Wireless
Requires a home wireless network in order to function
Automatic Updates
Convenient automatic firmware updates
  • Remote monitoring
    Live video on your mobile devices, tablets, and computers from any Internet connection.
  • Two-way audio
  • Night vision
    See your baby in complete darkness with night vision.
  • Mounting base
    It offers adjustable mounting base for flat and vertical surfaces.
  • Recording
    Record video to a remote storage device.
TRENDnet TV - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
7 cm x 6.5 cm x 8.8 cm
102 g
Wireless
Camera
Colour - Day&Night
Max Resolution
640 x 480
Frame Rate (max)
30 frames per second
Motion Detection
Optical Sensor Type
CMOS - 1/5"
Minimum Illumination
0 lux - IR , 1 lux - colour - F2.8
Focal Length
3.6 mm
Focus Adjustment
(min distance 20 cm)
Lens Iris
F/2.8
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage
DC 5 V
White balance, saturation control, contrast control, image flip, image mirror, Video Snapshot mode, Motion Detection Technology, light sensor, Sound Detection Sensor, Wi-Fi Protected Setup (WPS), reset button, music play button, pre-installed lullabies
3-year warranty
Environmental Parameters (operating)
0 °C - 40 °C; 0 - 85% (non-condensing) relative humidity
Audio Support
Wireless
7 cm
6.5 cm
8.8 cm
102 g
Camera
Colour - Day&Night - fixed
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
640 x 480
Motion Detection
Digital Zoom
4
Infrared Distance
5 m
Video Capture
640 x 480 @ 30 fps
Still Image Capture Resolution
640 x 480
Image Sensor
CMOS 1/5"
Lens Construction
Focal Length
3.6 mm
Lens Iris
F/2.8
Min Focus Distance
20 cm
Horizontal Field of View (degree)
45
Vertical Field of View (degree)
35
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, RTSP, RTP, UPnP, IPv4, Bonjour, RTCP, Samba, 3GPP/ISMA, LLTD
Ports
USB (power only) - Micro-USB Type B
Camera mount base
FCC, RoHS, WEEE
Power Requirements
DC 5 V - 1 A
Power adapter - external AC 120/230 V (50/60 Hz) 5 Watt
Software Included
TRENDnet CloudView
Limited warranty - 3 years
Relative Humidity (operating)
Brand: TRENDnet
Price Range Ex VAT: 0 - 50
