TRENDnet TV-IP450PI Outdoor 1.3 MP HD PoE IR Speed Dome Network Camer
Quicklinx: 9QTTWS00 Mfr#: TV-IP450PI
  • microSD Card
£637.02 ex VAT
£764.42 inc VAT
TRENDnet's Outdoor 1.3 MP HD PoE IR Speed Dome Network Camera, model TV-IP450PI, offers powerful 20x optical zoom, 100 m (330 feet) night vision, an IP66 weather rating, and endless 360 degree PTZ functionality. Record 1.3 Megapixel HD video (1280 x 960) at 30 fps in a space saving H.264 compression format.
Manage up to 32 TRENDnet cameras with included complimentary software and mobile apps.
A separate mounting bracket is required--install with TRENDnet's TV-HC400, TV-HW400, TV-HP400, or TV-HN400.
  • Powerful zoom
    20x optical zoom and 16x digital zoom combine for a total 320x zoom factor with autofocus.
  • Smart IR
    Night vision up to 100 meters (330 ft.) automatically adjusts to the zoom factor.
  • Endless PTZ
    Continuous 360° variable speed pan tilt zoom and user defined 3D zoom within the graphical user interface.
  • Outdoor rated
    Built for extreme environments with an IP66 weather rating and an operating temperature range of -30 - 65 °C (-22 - 149 °F).
  • 1.3 Megapixel HD
    Record 1280 x 960 at 30 fps in the space saving H.264 compression format.
TRENDnet TV TV-IP450PI Outdoor 1.3 MP HD PoE IR Speed Dome Network Camera - network surveillance camera
Network surveillance camera - pan / tilt / zoom - outdoor - weatherproof
Audio
Yes: two-way audio capability
22 cm x 22 cm x 35.4 cm
4.4 kg
Wired
Camera
Colour - Day&Night
Optical Zoom
20 x
Max Resolution
1280 x 960
Frame Rate (max)
30 frames per second
Motion Detection
Optical Sensor Type
CMOS - 1/3" - 1.3 MP
Minimum Illumination
0.05 lux - colour , 0.01 lux - B&W , 0 lux - IR
Focal Length Control
Motorized zoom
Focal Length
4.7 mm - 94 mm
Focus Adjustment
Automatic, manual
Lens Iris
F/1.4-3.5
Panning Range (degree)
360
Tilting Range (degree)
-5 to 90
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Digital noise reduction, sharpness control, remote control, white balance, saturation control, brightness control, contrast control, image mirror, heater, manually schedule recording, auto patrol, Motion Detection Technology, microSD card slot, Privacy Mask Function, Digital Wide Dynamic Range (D-WDR), 256 preset positions, tamper-detection, notification picture to E-mail, ONVIF V2.2 (Profile S) support, snapshot function
3-year warranty
Environmental Parameters (operating)
-30 °C - 65 °C; 0 - 90% (non-condensing) relative humidity
Audio Support
Wired
22 cm
22 cm
35.4 cm
4.4 kg
Camera
Colour - Day&Night - pan / tilt / zoom - outdoor - weatherproof
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1280 x 960
Motion Detection
Digital Zoom
16
Exposure Range
1 sec - 1/10000 sec
Infrared Distance
100 m
Video Capture
1280 x 960 @ 30 fps , 704 x 480 @ 30 fps
Still Image Capture Resolution
1280 x 960, 704 x 480
Image Sensor
1.3 MP CMOS 1/3"
Lens Construction
Motorized zoom
Optical Zoom
20 x
Focal Length
4.7 mm - 94 mm
Lens Iris
F/1.4-3.5
Focus Adjustment
Automatic, manual
Horizontal Field of View (degree)
54
Panning
Range (degree)
360
Speed (degree/sec)
Up to 240
Titling
Range (degree)
-5 to 90
Speed (degree/sec)
Up to 200
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, SNMP 1, SNMP 2c, SNMP 3, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, PPPoE, SMB, IGMP, CIFS
Supported Memory Cards
microSD Card
Power injector
FCC, IP66
Power Requirements
PoE
35 Watt
Software Included
Drivers & Utilities, TRENDnetVIEW Pro
Microsoft Windows Server 2003, Microsoft Windows Vista / XP, Microsoft Windows Server 2008, Android, Apple iOS, Microsoft Windows 7 / Windows 8, Windows 8.1
Limited warranty - 3 years
-30 °C
65 °C
Relative Humidity (operating)
Brand: TRENDnet
Price Range Ex VAT: 500 - 750
