Product
TRENDnet TV-IP430PI Outdoor 2MP Full HD PoE+ IR Speed Dome IP Camera
Quicklinx: BKGQWS00 Mfr#: TV-IP430PI
  • microSD Card
£338.40 ex VAT
£406.08 inc VAT
TRENDnet’s Outdoor 2 MP Full HD 1080p PoE IR Mini Speed Dome Network Camera, model TV-IP430PI, offers 4x optical zoom, 30 meter (100 feet) night vision, an IP66 weather rating, and endless 360 degree PTZ functionality. Record 2 Megapixel HD video (1920 x 1080) at 30 fps in a space saving H.264 compression format. Manage up to 32 TRENDnet cameras with included complimentary software and mobile apps. A separate mounting bracket is required—install with TRENDnet’s TV-HC400, TV-HW400, TV-HP400, or TV-HN400.
Endless PTZ
Endless 360° pan/tilt/zoom, user defined 64x zoom, and autofocus capabilities maximize surveillance coverage.
Day/Night HD Surveillance
Full 1080p HD (2 MP) video at 30 fps in H.264 compression and 30 meter rated night vision provide 24-hour surveillance.
Outdoor Ready
Built for extreme environments with an IP66 weather rating and an operating temperature range of -30 – 65 °C (-22 – 149 °F).
2 Megapixel Full 1080p HD
Record 1920 x 1080 at 30 fps in the space saving H.264 compression format
Powerful Zoom
4x optical zoom and 16x digital zoom combine for a total 64x zoom factor with autofocus
Smart IR
Night vision up to 30 meters (100 ft.) automatically adjusts to the zoom factor
Endless PTZ
Endless 360° variable speed pan tilt zoom and user defined 3D zoom within the web interface
Outdoor Rated
PoE+
Includes a PoE+ injector (30 Watts) and is compatible with 802.3at PoE+ switches
Additional Mounting Bracket Required
Separate mounting bracket required—install with TRENDnet’s TV-HC400, TV-HW400, TV-HP400, or TV-HN400
Auto Patrol
Choose pre-defined or program auto patrol sequences with varying zoom levels
Storage
Record video to a Samba client or to a Micro SD card (up to 32 GB sold separately)
Tamper Detection
Receive tamper detection video clips via email, ftp, or save to Samba client or Micro SD card
D-WDR
Improved image quality and autofocus in high contrast lighting environments with Digital Wide Dynamic Range technology
Recording Schedule
Define a weekly recording schedule
IPv6
IPv6 support
ONVIF
ONVIF compliant
Complimentary Software
Complimentary pro-grade software to manage up to 32 TRENDnet cameras
Complimentary Apps
Live video to a mobile device with free iOS® and Android™ apps
TRENDnet TV IP430PI - network surveillance camera
Network surveillance camera - pan / tilt / zoom - outdoor - weatherproof
Audio
Yes: two-way audio capability
15.5 cm x 15.5 cm x 23.5 cm
2 kg
Wired
Camera
Colour - Day&Night
Optical Zoom
4 x
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Motion Detection
Optical Sensor Type
CMOS - 1/2.8" - 2 MP
Minimum Illumination
0.05 lux - colour , 0.01 lux - B&W , 0 lux - IR
Focal Length Control
Motorized zoom
Focal Length
2.8 mm - 12 mm
Focus Adjustment
Automatic, manual
Lens Iris
F/1.6-2.7 - auto and manual iris
Panning Range (degree)
360
Tilting Range (degree)
-10 to 90
Ethernet 10Base-T/100Base-TX
Voltage
PoE Plus
Backlight compensation, digital noise reduction, date/time stamp, sharpness control, white balance, alarm function, progressive scanning, saturation control, brightness control, contrast control, image flip, image mirror, heater, manually schedule recording, auto patrol, Motion Detection Technology, Privacy Mask Function, Digital Wide Dynamic Range (D-WDR), Highlight Compensation (HLC), 256 preset positions, surge protection, tamper-detection, notification picture to E-mail, ONVIF V2.2 (Profile S) support, lightning-resistant, Defog
3 years warranty
Environmental Parameters (operating)
-30 °C - 65 °C; 0 - 90% (non-condensing) relative humidity
Audio Support
Wired
15.5 cm
15.5 cm
23.5 cm
2 kg
Camera
Colour - Day&Night - pan / tilt / zoom - outdoor - weatherproof
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Digital Zoom
16
Exposure Range
1 sec - 1/10000 sec
Infrared LEDs
Infrared Distance
30 m
Video Capture
1920 x 1080 @ 30 fps , 704 x 480 @ 30 fps
Still Image Capture Resolution
704 x 480, 1920 x 1080
Image Sensor
2 MP CMOS 1/2.8"
Lens Construction
Motorized zoom
Optical Zoom
4 x
Focal Length
2.8 mm - 12 mm
Lens Iris
F/1.6-2.7 auto and manual iris
Focus Adjustment
Automatic, manual
Horizontal Field of View (degree)
33.8 - 115
Panning
Range (degree)
360
Speed (degree/sec)
Up to 160
Titling
Range (degree)
-10 to 90
Speed (degree/sec)
Up to 120
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, SNMP 1, SNMP 2c, SNMP 3, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, PPPoE, SMB, QOS, CIFS, NFS
Supported Memory Cards
microSD Card
Power injector
FCC, IP66
Power Requirements
PoE Plus
20 Watt
Microsoft Windows Server 2003, Microsoft Windows Vista / XP, Microsoft Windows Server 2008, Android, Apple iOS, Microsoft Windows 7 / Windows 8, Windows 8.1, Windows 10
Limited warranty - 3 years
-30 °C
65 °C
Relative Humidity (operating)
Brand: TRENDnet
Price Range Ex VAT: 300 - 500
