TRENDnet’s Outdoor 2 MP Full HD 1080p PoE IR Mini Speed Dome Network Camera, model TV-IP430PI, offers 4x optical zoom, 30 meter (100 feet) night vision, an IP66 weather rating, and endless 360 degree PTZ functionality. Record 2 Megapixel HD video (1920 x 1080) at 30 fps in a space saving H.264 compression format. Manage up to 32 TRENDnet cameras with included complimentary software and mobile apps. A separate mounting bracket is required—install with TRENDnet’s TV-HC400, TV-HW400, TV-HP400, or TV-HN400.
Endless PTZ
Endless 360° pan/tilt/zoom, user defined 64x zoom, and autofocus capabilities maximize surveillance coverage.
Day/Night HD Surveillance
Full 1080p HD (2 MP) video at 30 fps in H.264 compression and 30 meter rated night vision provide 24-hour surveillance.
Outdoor Ready
Built for extreme environments with an IP66 weather rating and an operating temperature range of -30 – 65 °C (-22 – 149 °F).
2 Megapixel Full 1080p HD
Record 1920 x 1080 at 30 fps in the space saving H.264 compression format
Powerful Zoom
4x optical zoom and 16x digital zoom combine for a total 64x zoom factor with autofocus
Smart IR
Night vision up to 30 meters (100 ft.) automatically adjusts to the zoom factor
Endless PTZ
Endless 360° variable speed pan tilt zoom and user defined 3D zoom within the web interface
Outdoor Rated
PoE+
Includes a PoE+ injector (30 Watts) and is compatible with 802.3at PoE+ switches
Additional Mounting Bracket Required
Separate mounting bracket required—install with TRENDnet’s TV-HC400, TV-HW400, TV-HP400, or TV-HN400
Auto Patrol
Choose pre-defined or program auto patrol sequences with varying zoom levels
Storage
Record video to a Samba client or to a Micro SD card (up to 32 GB sold separately)
Tamper Detection
Receive tamper detection video clips via email, ftp, or save to Samba client or Micro SD card
D-WDR
Improved image quality and autofocus in high contrast lighting environments with Digital Wide Dynamic Range technology
Recording Schedule
Define a weekly recording schedule
IPv6
IPv6 support
ONVIF
ONVIF compliant
Complimentary Software
Complimentary pro-grade software to manage up to 32 TRENDnet cameras
Complimentary Apps
Live video to a mobile device with free iOS® and Android™ apps
- TRENDnet TV IP430PI - network surveillance camera
- Network surveillance camera - pan / tilt / zoom - outdoor - weatherproof
- Audio
- Yes: two-way audio capability
- 15.5 cm x 15.5 cm x 23.5 cm
- 2 kg
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Optical Zoom
- 4 x
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Optical Sensor Type
- CMOS - 1/2.8" - 2 MP
- Minimum Illumination
- 0.05 lux - colour , 0.01 lux - B&W , 0 lux - IR
- Focal Length Control
- Motorized zoom
- Focal Length
- 2.8 mm - 12 mm
- Focus Adjustment
- Automatic, manual
- Lens Iris
- F/1.6-2.7 - auto and manual iris
- Panning Range (degree)
- 360
- Tilting Range (degree)
- -10 to 90
- Ethernet 10Base-T/100Base-TX
- Voltage
- PoE Plus
- Backlight compensation, digital noise reduction, date/time stamp, sharpness control, white balance, alarm function, progressive scanning, saturation control, brightness control, contrast control, image flip, image mirror, heater, manually schedule recording, auto patrol, Motion Detection Technology, Privacy Mask Function, Digital Wide Dynamic Range (D-WDR), Highlight Compensation (HLC), 256 preset positions, surge protection, tamper-detection, notification picture to E-mail, ONVIF V2.2 (Profile S) support, lightning-resistant, Defog
- 3-year warranty
- Environmental Parameters (operating)
- -30 °C - 65 °C; 0 - 90% (non-condensing) relative humidity
- Audio Support
- Wired
- 15.5 cm
- 15.5 cm
- 23.5 cm
- 2 kg
Camera
- Colour - Day&Night - pan / tilt / zoom - outdoor - weatherproof
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Digital Zoom
- 16
- Exposure Range
- 1 sec - 1/10000 sec
- Infrared LEDs
- Infrared Distance
- 30 m
- Video Capture
- 1920 x 1080 @ 30 fps , 704 x 480 @ 30 fps
- Still Image Capture Resolution
- 704 x 480, 1920 x 1080
Image Sensor
- 2 MP CMOS 1/2.8"
Lens Construction
- Motorized zoom
- Optical Zoom
- 4 x
- Focal Length
- 2.8 mm - 12 mm
- Lens Iris
- F/1.6-2.7 auto and manual iris
- Focus Adjustment
- Automatic, manual
- Horizontal Field of View (degree)
- 33.8 - 115
Panning
- Range (degree)
- 360
- Speed (degree/sec)
- Up to 160
Tilting
- Range (degree)
- -10 to 90
- Up to 120
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, SNMP 1, SNMP 2c, SNMP 3, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, PPPoE, SMB, QOS, CIFS, NFS
- Supported Memory Cards
- microSD Card
- Included Accessories
- Power injector
- FCC, IP66
- Power Requirements
- PoE Plus
- Power Device
- 20 Watt
- OS Required
- Microsoft Windows Server 2003, Microsoft Windows Vista / XP, Microsoft Windows Server 2008, Android, Apple iOS, Microsoft Windows 7 / Windows 8, Windows 8.1, Windows 10
- Limited warranty - 3 years
- -30 °C
- 65 °C
- Relative Humidity (operating)
- 0 - 90% (non-condensing)
