The Outdoor 1.3 MP HD PoE dome IR Network Camera, model TV-IP321PI provides powerful night vision in complete darkness for up to 25 meters.
This ultra-compact vandal resistant fixed dome camera is outdoor ready with an IP66 weather rated housing.
It comes with a free Apple and Android mobile app and complimentary pro-grade software to manage up to 32 TRENDnet cameras.
- TRENDnet TV IP321PI - network surveillance camera
- Network surveillance camera - pan / tilt - outdoor - vandal / weatherproof
- 11.1 cm x 11.1 cm x 8.2 cm
- 370 g
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Max Resolution
- 1280 x 960
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Optical Sensor Type
- CMOS - 1/3" - 1.3 MP
- Minimum Illumination
- 0.01 lux - colour - F2.0 , 0 lux - IR
- Focal Length
- 4 mm
- Focus Adjustment
- (min distance 20 cm)
- Panning Range (degree)
- 355
- Tilting Range (degree)
- 15 to 90
- Ethernet 10Base-T/100Base-TX
- Voltage
- DC 12 V / PoE
- Digital noise reduction, date/time stamp, sharpness control, white balance, progressive scanning, saturation control, brightness control, contrast control, e-mail alerts, image mirror, Wide Dynamic Range (WDR), ONVIF support, 3D Noise Reduction Technology, manually schedule recording, Motion Detection Technology, built-in IR illuminator, Privacy Mask Function, Digital Wide Dynamic Range (D-WDR), text stamp, tamper-detection, Smart IR, ONVIF V2.2 (Profile S) support, snapshot function
- 3-year warranty
- Environmental Parameters (operating)
- -30 °C - 60 °C; 0 - 95% (non-condensing) relative humidity
- Wired
- 11.1 cm
- 11.1 cm
- 8.2 cm
- 370 g
Camera
- Colour - Day&Night - pan / tilt - outdoor - vandal / weatherproof
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 1280 x 960
- Motion Detection
- Exposure Range
- 1/3 sec - 1/10000 sec
- Infrared Distance
- 25 m
- Video Capture
- 704 x 480 @ 30 fps , 1280 x 960 @ 30 fps
- Still Image Capture Resolution
- 1280 x 960, 704 x 480
Image Sensor
- 1.3 MP CMOS 1/3"
Lens Construction
- Focal Length
- 4 mm
- Min Focus Distance
- 20 cm
- Horizontal Field of View (degree)
- 70
- Vertical Field of View (degree)
- 52
Panning
- Range (degree)
- 355
Tilting
- Range (degree)
- 15 to 90
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, SNMP 1, SNMP 2c, SNMP 3, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, Bonjour, RTCP, PPPoE, SMB, SSL, CIFS
- Ports
- LAN/power - RJ-45
- Included Accessories
- Mounting kit
- UL 60950, FCC, IEC 60068-2-75, IK10, IP66
- Power Requirements
- DC 12 V / PoE - 1 A
- Power Device
- Power adapter 7 Watt
- Software Included
- TRENDnetVIEW Pro
- OS Required
- Microsoft Windows Server 2003, Microsoft Windows Vista / XP, Microsoft Windows Server 2008, Microsoft Windows 7 / 8 / 8.1
- Limited warranty - 3 years
- -30 °C
- 60 °C
- Relative Humidity (operating)
- 0 - 95% (non-condensing)
