Product
TRENDnet TV-IP321PI Outdoor 1.3 MP HD PoE Dome IR Network Camera
Clearance!
Clearance
Last Few Remaining
Limited Time Offer
Quicklinx: B3XYWS00 Mfr#: TV-IP321PI
The Outdoor 1.3 MP HD PoE dome IR Network Camera, model TV-IP321PI provides powerful night vision in complete darkness for up to 25 meters.
This ultra-compact vandal resistant fixed dome camera is outdoor ready with an IP66 weather rated housing.
It comes with a free Apple and Android mobile app and complimentary pro-grade software to manage up to 32 TRENDnet cameras.
TRENDnet TV IP321PI - network surveillance camera
Network surveillance camera - pan / tilt - outdoor - vandal / weatherproof
11.1 cm x 11.1 cm x 8.2 cm
370 g
Wired
Camera
Colour - Day&Night
Max Resolution
1280 x 960
Frame Rate
30 frames per second
Motion Detection
Optical Sensor Type
CMOS - 1/3" - 1.3 MP
Minimum Illumination
0.01 lux - colour - F2.0 , 0 lux - IR
Focal Length
4 mm
Focus Adjustment
(min distance 20 cm)
Panning Range (degree)
355
Tilting Range (degree)
15 to 90
Ethernet 10Base-T/100Base-TX
Voltage
DC 12 V / PoE
Digital noise reduction, date/time stamp, sharpness control, white balance, progressive scanning, saturation control, brightness control, contrast control, e-mail alerts, image mirror, Wide Dynamic Range (WDR), ONVIF support, 3D Noise Reduction Technology, manually schedule recording, Motion Detection Technology, built-in IR illuminator, Privacy Mask Function, Digital Wide Dynamic Range (D-WDR), text stamp, tamper-detection, Smart IR, ONVIF V2.2 (Profile S) support, snapshot function
3 years warranty
Environmental Parameters (operating)
-30 °C - 60 °C; 0 - 95% (non-condensing) relative humidity
Wired
11.1 cm
11.1 cm
8.2 cm
370 g
Camera
Colour - Day&Night - pan / tilt - outdoor - vandal / weatherproof
Digital Video Format
H.264
Max Digital Video Resolution
1280 x 960
Motion Detection
Exposure Range
1/3 sec - 1/10000 sec
Infrared Distance
25 m
Frame Rate
Still Image Capture Resolution
1280 x 960, 704 x 480
Image Sensor
1.3 MP CMOS 1/3"
Lens Construction
Focal Length
4 mm
Min Focus Distance
20 cm
Horizontal Field of View (degree)
70
Vertical Field of View (degree)
52
Panning
Range (degree)
355
Titling
Range (degree)
15 to 90
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, SNMP 1, SNMP 2c, SNMP 3, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, Bonjour, RTCP, PPPoE, SMB, SSL, CIFS
Ports
LAN/power - RJ-45
Mounting kit
UL 60950, FCC, IEC 60068-2-75, IK10, IP66
Power Requirements
DC 12 V / PoE - 1 A
Power adapter 7 Watt
Software Included
TRENDnetVIEW Pro
Microsoft Windows Server 2003, Microsoft Windows Vista / XP, Microsoft Windows Server 2008, Microsoft Windows 7 / 8 / 8.1
Limited warranty - 3 years
-30 °C
60 °C
Relative Humidity (operating)
