The Outdoor 1.3 MP HD PoE IR Network Camera Twin Pack, model TV-IP320PI2K, comes with two TV-IP320PI cameras which provide powerful 1.3 megapixel HD night vision in complete darkness for up to 30 meters (100 ft.). The ultra-compact cameras are outdoor ready with an IP66 weather rated housing. They come with a free iOS® and Android™ mobile app and Complimentary pro-grade software to manage up to 32 TRENDnet cameras.
Hardware - Cameras
Includes two TV-IP320PI cameras
Adjustable Bracket
Fully adjustable integrated mounting bracket provides installation flexibility
PoE
Save installation costs with Power over Ethernet (IEEE 802.3af)
Outdoor Ready
Outdoor IP66 weather rated and an operating temperature range of -30 - 60 °C (-22 - 140 °F)
1.3 Megapixel
Record 1280 x 960 pixel video at 30 fps in H.264 compression
Night Vision
Night vision up to 30 meters (100 ft.) in complete darkness
Smart IR
Dynamic IR adjustment optimizes night visibility
D-WDR
Digital Wide Dynamic Range improves video quality in high contrast lighting environments
Advanced Playback
Advanced in-camera archived video review functionality
Dynamic DNS Support
Support for dyn.com and NO-IP.org
Storage
SMB/CIFS support with notification if storage drive is full
Motion Detection
Create motion detection windows with separate sensitivity settings and event triggers
Recording Schedule
Define a weekly recording schedule
IPv6
IPv6 support
ONVIF
ONVIF v2.2 compliant
Free Apps
See live video on a mobile device with free iOS® and Android™ apps
Complimentary Software
Complimentary pro-grade software to manage up to TRENDnet 32 cameras
Adjustable bracket
Fully adjustable integrated mounting bracket provides installation flexibility. -
PoE
Save installation costs with Power over Ethernet (IEEE 802.3af). -
Night vision
Ensures night vision up to 30 meters (100 ft.) in complete darkness. -
Smart IR
Dynamic IR adjustment optimizes night visibility. -
D-WDR
Digital Wide Dynamic Range improves video quality in high contrast lighting environments. -
Storage
SMB/CIFS support with notification if storage drive is full. -
Motion detection
Create motion detection windows with separate sensitivity settings and event triggers. -
Recording schedule
Define a weekly recording schedule.
- TRENDnet TV IP320PI2K - network surveillance camera
- Network surveillance camera - fixed - outdoor - weatherproof
- Packaged Quantity
- 2 (specifications are for single item)
- 6 cm x 15.2 cm x 6 cm
- 375 g
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Max Resolution
- 1280 x 960
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Optical Sensor Type
- CMOS - 1/3" - 1.3 MP
- Minimum Illumination
- 0.01 lux - colour - F2.0 , 0 lux - IR
- Focal Length
- 4 mm
- Focus Adjustment
- (min distance 20 cm)
- Ethernet 10Base-T/100Base-TX
- Voltage
- DC 12 V / PoE
- Digital noise reduction, date/time stamp, sharpness control, white balance, saturation control, contrast control, e-mail alerts, ONVIF support, Video Snapshot mode, 3D Noise Reduction Technology, manually schedule recording, Motion Detection Technology, Privacy Mask Function, Digital Wide Dynamic Range (D-WDR), text stamp, tamper-detection, Smart IR, ONVIF V2.2 (Profile S) support, reset button
- 3-year warranty
- Environmental Parameters (operating)
- -30 °C - 60 °C; 0 - 95% (non-condensing) relative humidity
- Packaged Quantity
- Wired
- 6 cm
- 15.2 cm
- 6 cm
- 375 g
Camera
- Colour - Day&Night - fixed - outdoor - weatherproof
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 1280 x 960
- Motion Detection
- Exposure Range
- 1/3 sec - 1/10000 sec
- Infrared Distance
- 30 m
- Video Capture
- 704 x 480 @ 30 fps , 1280 x 960 @ 30 fps
- Still Image Capture Resolution
- 1280 x 960, 704 x 480
Image Sensor
- 1.3 MP CMOS 1/3"
Lens Construction
- Focal Length
- 4 mm
- Min Focus Distance
- 20 cm
- Horizontal Field of View (degree)
- 70
- Vertical Field of View (degree)
- 52
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, SNMP 1, SNMP 2c, SNMP 3, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, Bonjour, RTCP, PPPoE, SMB, SSL, QOS, CIFS
- Ports
- LAN/power - RJ-45
- Included Accessories
- Mounting bracket
- UL 60950, FCC, IP66
- Power Requirements
- DC 12 V / PoE - 1 A
- Power Device
- Power adapter 7 Watt
- Software Included
- TRENDnetVIEW Pro
- OS Required
- Microsoft Windows Server 2003, Microsoft Windows Vista / XP, Microsoft Windows Server 2008, Microsoft Windows 7 / 8 / 8.1
- Limited warranty - 3 years
- -30 °C
- 60 °C
- Relative Humidity (operating)
- 0 - 95% (non-condensing)
