TRENDnet TV-IP320PI2K Outdoor 1.3 MP HD PoE IR IP Camera Twin Pack
Quicklinx: BBNRWS00 Mfr#: TV-IP320PI2K
The Outdoor 1.3 MP HD PoE IR Network Camera Twin Pack, model TV-IP320PI2K, comes with two TV-IP320PI cameras which provide powerful 1.3 megapixel HD night vision in complete darkness for up to 30 meters (100 ft.). The ultra-compact cameras are outdoor ready with an IP66 weather rated housing. They come with a free iOS® and Android™ mobile app and Complimentary pro-grade software to manage up to 32 TRENDnet cameras.
Hardware - Cameras
Includes two TV-IP320PI cameras
Adjustable Bracket
Fully adjustable integrated mounting bracket provides installation flexibility
PoE
Save installation costs with Power over Ethernet (IEEE 802.3af)
Outdoor Ready
Outdoor IP66 weather rated and an operating temperature range of -30 - 60 °C (-22 - 140 °F)
1.3 Megapixel
Record 1280 x 960 pixel video at 30 fps in H.264 compression
Night Vision
Night vision up to 30 meters (100 ft.) in complete darkness
Smart IR
Dynamic IR adjustment optimizes night visibility
D-WDR
Digital Wide Dynamic Range improves video quality in high contrast lighting environments
Advanced Playback
Advanced in-camera archived video review functionality
Dynamic DNS Support
Support for dyn.com and NO-IP.org
Storage
SMB/CIFS support with notification if storage drive is full
Motion Detection
Create motion detection windows with separate sensitivity settings and event triggers
Recording Schedule
Define a weekly recording schedule
IPv6
IPv6 support
ONVIF
ONVIF v2.2 compliant
Free Apps
See live video on a mobile device with free iOS® and Android™ apps
Complimentary Software
Complimentary pro-grade software to manage up to TRENDnet 32 cameras
  • Adjustable bracket
    Fully adjustable integrated mounting bracket provides installation flexibility.
  • PoE
    Save installation costs with Power over Ethernet (IEEE 802.3af).
  • Night vision
    Ensures night vision up to 30 meters (100 ft.) in complete darkness.
  • Smart IR
    Dynamic IR adjustment optimizes night visibility.
  • D-WDR
    Digital Wide Dynamic Range improves video quality in high contrast lighting environments.
  • Storage
    SMB/CIFS support with notification if storage drive is full.
  • Motion detection
    Create motion detection windows with separate sensitivity settings and event triggers.
  • Recording schedule
    Define a weekly recording schedule.
TRENDnet TV IP320PI2K - network surveillance camera
Network surveillance camera - fixed - outdoor - weatherproof
Packaged Quantity
2 (specifications are for single item)
6 cm x 15.2 cm x 6 cm
375 g
Wired
Camera
Colour - Day&Night
Max Resolution
1280 x 960
Frame Rate (max)
30 frames per second
Motion Detection
Optical Sensor Type
CMOS - 1/3" - 1.3 MP
Minimum Illumination
0.01 lux - colour - F2.0 , 0 lux - IR
Focal Length
4 mm
Focus Adjustment
(min distance 20 cm)
Ethernet 10Base-T/100Base-TX
Voltage
DC 12 V / PoE
Digital noise reduction, date/time stamp, sharpness control, white balance, saturation control, contrast control, e-mail alerts, ONVIF support, Video Snapshot mode, 3D Noise Reduction Technology, manually schedule recording, Motion Detection Technology, Privacy Mask Function, Digital Wide Dynamic Range (D-WDR), text stamp, tamper-detection, Smart IR, ONVIF V2.2 (Profile S) support, reset button
3-year warranty
Environmental Parameters (operating)
-30 °C - 60 °C; 0 - 95% (non-condensing) relative humidity
Packaged Quantity
Wired
6 cm
15.2 cm
6 cm
375 g
Camera
Colour - Day&Night - fixed - outdoor - weatherproof
Digital Video Format
H.264
Max Digital Video Resolution
1280 x 960
Motion Detection
Exposure Range
1/3 sec - 1/10000 sec
Infrared Distance
30 m
Video Capture
704 x 480 @ 30 fps , 1280 x 960 @ 30 fps
Still Image Capture Resolution
1280 x 960, 704 x 480
Image Sensor
1.3 MP CMOS 1/3"
Lens Construction
Focal Length
4 mm
Min Focus Distance
20 cm
Horizontal Field of View (degree)
70
Vertical Field of View (degree)
52
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, SNMP 1, SNMP 2c, SNMP 3, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, Bonjour, RTCP, PPPoE, SMB, SSL, QOS, CIFS
Ports
LAN/power - RJ-45
Mounting bracket
UL 60950, FCC, IP66
Power Requirements
DC 12 V / PoE - 1 A
Power adapter 7 Watt
Software Included
TRENDnetVIEW Pro
Microsoft Windows Server 2003, Microsoft Windows Vista / XP, Microsoft Windows Server 2008, Microsoft Windows 7 / 8 / 8.1
Limited warranty - 3 years
-30 °C
60 °C
Relative Humidity (operating)
