TRENDnet's 4-port USB 3.0 mini hub, model TU3-H4E, instantly adds four 5 Gbps SuperSpeed USB 3.0 ports to a computer. No CD installation required-simply plug in flash drives, storage enclosures, and other USB 3.0 devices at speeds ten times faster than a USB 2.0 connection. The TU3-H4E is also compatible with older USB 2.0 and 1.1 ports.
- TRENDnet TU3 H4E - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 4 x SuperSpeed USB 3.0
- USB powered
- USB 1.1, USB 2.0, USB 3.0
- 8 cm x 3.7 cm x 1.3 cm
- 35 g
- 2-year warranty
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- USB powered
- Status Indicators
- USB
- 4 x USB 3.0 Type A
- 4.5 Watt
- Cables Included
- 1 x SuperSpeed USB cable - 14 cm
- Plug and Play, FCC
- 8 cm
- 3.7 cm
- 1.3 cm
- 35 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
