TRENDnet TU2-H10 10-Port USB Hub
Quicklinx: 9Q62WS00 Mfr#: TU2-H10
Type: USB Hub
Ports: 10
£27.46 ex VAT
£32.95 inc VAT
TRENDnet's 10-Port USB Hub, model TU2-H10, adds 10 USB 2.0 ports to a workstation. No CD installation required-simply plug in flash drives, storage enclosures, and other USB devices. The TU2-H10 works with Windows® and Mac® devices and is compatible with older USB 1.1 and 1.0 devices.
Ease of Use
Easy Setup
No CD installation - just plug in
Computer Connection
Includes a long 90 cm (35 in.) USB cable to connect to computer
Operating Systems
Compatible with Windows® and Mac® operating systems
LED Indicators
LED indicators confirm USB connectivity
Power Adapter
Provides up to 12.5 Watts of total power
Not for charging iPad® tablets or other non-standard USB 2.0 chargers
Maximum power output for a bus powered hub is up to 500 mA. Power adapter required when total power consumption exceeds 500 mA.
Header / Manufacturer
TRENDnet
Header / Product Line
TRENDnet TU2
Networking / Subcategory
Peripheral sharing and hubs
Networking / Type
Hub
Networking / Subtype
USB
Networking / Form Factor
Desktop
Ports
10
Header / Packaged Quantity
1
Dimensions & Weight / Weight
134 g
Dimensions & Weight / Width
15.6 cm
Dimensions & Weight / Height
2 cm
Service & Support / Type
2 years warranty
Dimensions & Weight / Depth
7.4 cm
Header / Model
H10
Header / Compatibility
Mac, PC
Type: USB Hub
Ports: 10
Brand: TRENDnet
