TRENDnet's 10-Port USB Hub, model TU2-H10, adds 10 USB 2.0 ports to a workstation. No CD installation required-simply plug in flash drives, storage enclosures, and other USB devices. The TU2-H10 works with Windows® and Mac® devices and is compatible with older USB 1.1 and 1.0 devices.
Ease of Use
Easy Setup
No CD installation - just plug in
Computer Connection
Includes a long 90 cm (35 in.) USB cable to connect to computer
Operating Systems
Compatible with Windows® and Mac® operating systems
LED Indicators
LED indicators confirm USB connectivity
Power Adapter
Provides up to 12.5 Watts of total power
Not for charging iPad® tablets or other non-standard USB 2.0 chargers
* Maximum power output for a bus powered hub is up to 500 mA. Power adapter required when total power consumption exceeds 500 mA.
- Header / Manufacturer
- TRENDnet
- Header / Product Line
- TRENDnet TU2
- Networking / Subcategory
- Peripheral sharing and hubs
- Networking / Type
- Hub
- Networking / Subtype
- USB
- Networking / Form Factor
- Desktop
- Ports
- 10
- Header / Packaged Quantity
- 1
- Dimensions & Weight / Weight
- 134 g
- Dimensions & Weight / Width
- 15.6 cm
- Dimensions & Weight / Height
- 2 cm
- Service & Support / Type
- 2 years warranty
- Dimensions & Weight / Depth
- 7.4 cm
- Header / Model
- H10
- Header / Compatibility
- Mac, PC
