TRENDnet TPE-TG50G 5-Port Gigabit PoE+ Switch
Quicklinx: 9Q65WS00 Mfr#: TPE-TG50G
Type: Gigabit Ethernet
Ports: 5
Data Transfer Rate: 1Gbps
Managed: No
POE: PoE+
12 in stock
£46.17 ex VAT
£55.40 inc VAT
The 5-port Gigabit PoE+ switch, model TPE-TG50g, delivers data and power over existing Ethernet cables to Power over Ethernet (PoE) devices such as Access Points and IP Cameras. It supports both PoE (802.3af) and PoE+ (802.3at) devices with a 31 watts PoE budget. Plug and Play this sturdy metal switch for reliable high speed PoE networking.
PoE+
Supplies up to 30 Watts of PoE power per port with a 31 Watt PoE budget
Ports
4 x Gigabit PoE+ ports and 1 x Gigabit port
Switching Capacity
10 Gbps switching capacity
Jumbo Frame
Sends larger packets, or Jumbo Frames (up to 9 KB) for increased performance
Energy Savings
Embedded GREENnet technology reduces power consumption by up to 70%*
Housing
Rugged metal enclosure
LED Indicators
LED indicators convey port status
Header / Manufacturer
TRENDnet
Networking / Subcategory
Network hubs and switches
Networking / Type
Switch
Networking / Form Factor
Desktop
Header / Model
TG50g
Gigabit Ethernet
POE
PoE+
Header / Compatibility
PC
Networking / Jumbo Frame Support
9KB
Dimensions & Weight / Depth
9.5 cm
Ports
5
Dimensions & Weight / Weight
370 g
Dimensions & Weight / Height
3 cm
Dimensions & Weight / Width
14.1 cm
Header / Packaged Quantity
1
Service & Support / Type
3 years warranty
Ports: 5
Managed: No
POE: PoE+
Brand: TRENDnet
Price Range Ex VAT: 0 - 50
