TRENDnet TPE-4840WS 48-Port Gigabit Web Smart PoE+ Switch
Quicklinx: B4Z1WS00 Mfr#: TPE-4840WS
TRENDnet's 48-Port Gigabit Web Smart PoE+ Switch, model TPE-4840WS, offers 12 x Gigabit PoE+ ports (ports 1-12 802.3at), 12 x Gigabit PoE ports (ports 13-24 802.3af), 24 x Gigabit ports (ports 25-48), 4 x shared SFP slots (shared with ports 45-48), and a PoE Power budget of 370 Watts. This IPv6 ready switch offers advanced traffic management, troubleshooting, access control, energy saving GREENnet, and monitoring features at a reduced cost.
Hardware Design
Provides 12 x Gigabit PoE+ ports (ports 1-12 802.3at), 12 x Gigabit PoE ports (ports 13-24 802.3af), 24 x Gigabit ports (ports 25-48), 4 x shared SFP slots (shared with ports 45-48), a PoE Power budget of 370 Watts, and includes rackmount brackets.
Smart Fan
Smart fan saves energy by varying fan speed and use based on cooling needs.
IPv6 Ready
This switch supports IPv6 configuration and IPv6 neighbor discovery.
Traffic Management
A broad range of network configurations are supported by: 802.3ad link aggregation, Asymmetric VLAN, 802.1Q VLAN, Voice VLAN, Private VLAN, Bandwidth Controls, GVRP, IGMP v1-v3, 802.1p Class of Service (CoS), Spanning Tree (STP, RSTP, and MSTP), and QoS queue scheduling.
Troubleshooting
Real time traffic comparison charts, error group charts, and a convenient cable diagnostic test aid in rapid troubleshooting.
Access Controls
Features such as ACL, SSL, MAC/port filtering, Denial of Service controls, 802.1X, TACACS+, and RADIUS are compatible with layered network access controls.
Monitoring RMON, SNMP, SNMP Trap, and Port Mirroring support administrator monitoring solutions.
  • Hardware design
    Provides 12 x Gigabit PoE+ ports, 12 x Gigabit PoE ports, 24 x Gigabit ports, 4 x shared SFP slots, a PoE power budget of 370 watts, and includes rackmount brackets.
  • Smart fan
  • IPv6 ready
  • Traffic management
  • Troubleshooting
  • Access controls
    Features such as ACL, SSL, MAC/port filtering, Denial of Service controls, 802.1x, TACACS+, and RADIUS are compatible with layered network access controls.
TRENDnet TPE 4840WS 48-Port Gigabit Web Smart PoE+ Switch - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
12 x 10/100/1000 (PoE+) + 12 x 10/100/1000 (PoE) + 24 x 10/100/1000 + 4 x shared Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
370 W
Performance
Switching capacity: 96 Gbps , Forwarding performance (64-byte packet size): 71.42 Mpps
MAC Address Table Size
16K entries
Jumbo Frame Support
10KB
Routing Protocol
IGMPv2, IGMP, IGMPv3, static IPv6 routing
Remote Management Protocol
SNMP 1, RMON 1, SNMP 3, SNMP 2c, HTTP, HTTPS
DHCP support, VLAN support, Weighted Round Robin (WRR) queuing, IPv6 support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Quality of Service (QoS), RADIUS support, reset button, Management Information Base (MIB), Dynamic VLAN Support (GVRP), Class of Service (CoS), tagged VLAN, Loopback, Denial of Service (DoS), Duplicated Address Detection, per port bandwidth control, DiffServ Code Point (DSCP) support, PoE overcurrent protection, PoE circuit sorting protection
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
44 cm x 43 cm x 4.4 cm
6.5 kg
Microsoft Windows Server 2003, Microsoft Windows Server 2008, Microsoft Windows Vista / XP / 7 / 8 / 8.1
3-year warranty
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
370 W
Performance
16K entries
Jumbo Frame Support
10KB
Routing Protocol
Encryption Algorithm
TLS, SSL 3.0, SSL 2.0
Authentication Method
RADIUS, TACACS+
RAM
1 MB
Status Indicators
Power, PoE, link/activity, SFP
12 x 1000Base-T RJ-45 PoE+ - 30 W , 12 x 1000Base-T RJ-45 PoE - 15.4 W , 24 x 1000Base-T RJ-45 , 4 x SFP
Internal power supply
55.6 Watt
Rack Mounting Kit
Included
MTBF
318,350 hours
UL 60950, FCC, RoHS, WEEE
44 cm
43 cm
4.4 cm
6.5 kg
Limited warranty - 3 years
-5 °C
45 °C
0 - 90% (non-condensing)
